click clack!! when idling
Old 11-29-2009, 11:47 AM
RODGERDODGER01's Avatar
Recently purchased a 2006 Ram w/ 5.9 and I find when truck is idling engine is noisy sounds like a knock click ! clack! wandering if it's valves or fuel related, are valves adjustable on those and if so what is the lash for intake and exhaust valves.......thanks mileage is 77000 miles
Old 11-29-2009, 02:47 PM
rich's Avatar
the valves are usaully good for about 150k. could be injector problems
Old 11-29-2009, 06:33 PM
Jeff in TD's Avatar
It wouldn't hurt to check the valves.
Remove the valve cover, rotate the engine with a barring tool or by the alternator pulley until the TDC mark on the damper is at 12 o'clock.
If both #1 valves are loose then #1 is between compression and power stroke, so adjust intake on 1, 2 and 4 and exhaust on 1, 3 and 5.
If both valves on #1 are not loose it's in overlap between exhaust stroke and intake, so you adjust intake on 3, 5, 6 and exhaust on 2, 4 and 6...
Feeler gauge goes between the rocker arm socket and the crossbar.
If the gap is within range (Intake is 0.006 to -.015 and exhaust is 0.015 to 0.030 with cold engine) then no adjustment is needed... If out of that range, then set intake at 0.010 and exhaust to 0.020. Torque lock nut to 24 Nm or 18 ft/lbs and recheck.
Then rotate the engine 360 and do whichever group you didn't do...
My guess is that you will find none out of range, but for peace of mind I'd check them...
You may very well have an injector problem, or possibly an exhaust leak.
Old 11-29-2009, 07:16 PM
Spooler's Avatar
Go get a heavy load and work the dog out of that truck. The previous owner could of used it as a grocery getter.
marksmith
08-17-2007 02:57 AM
Sleigher
03-23-2007 12:23 PM
cheapskate
19
12-27-2006 08:05 PM
PaulDaisy
12-02-2006 12:36 PM
bnold
04-25-2006 06:57 PM
Quick Reply: click clack!! when idling
