Advice for boost bolt location
Old 11-28-2004, 10:45 AM
03CTDCO's Avatar
I've seen some have drilled and tapped the intake horn, and others tapped into somewhere around the injector lines.
Can someone give me advice on the cleanest easist location
to get boost measurments for my boost gauge.
pyro and trans temp location are already picked out.
Also, best place to tap into 12v switched power to light up
my gauges
Thank you
Old 11-28-2004, 11:29 AM
MedicShawn's Avatar
I used a boost bolt for mine I have pics in my gallery. I just used the headlight switch for my bulb power/diming.
Old 11-28-2004, 11:46 AM
03CTDCO's Avatar
MedicShawn
Thanks, I've seen your pics for the relocation of HVAC. Nice job Dude !. I guess you added a new one for the boost bolt location.
That is perfect, I will do the same. So you removed one bolt that
mounts the intake horn and replaced it with your boost bolt.
Any special sealant required? and did you use standard teflon tape to seal the threads ?
About the headlight for switched/dimmed power source. How did
you access the harness? What color wire did you splice into ?
Where did you get the black harness sleeve on your boost line ?
Also, how did you prevent chips entering the turbo when drilling
and tapping for your pyro ?
Thank you
Old 11-28-2004, 11:51 AM
Dodgezilla's Avatar
I did the same as medicshawn. Your guage should have some instructions on the install. Mine came with the boost bolt....
Old 11-28-2004, 11:55 AM
03CTDCO's Avatar
Dodgezilla
No directions came with the boost bolt at all. I did get directions
with the gauges but they are generic except for the Dodge cubby mount bezel.
Just trying to get a little more info before I start.
Old 11-28-2004, 04:02 PM
R.M.THOMPSON's Avatar
The intake bolt directly under the #1,2 injector plug will work fine.Don't try to test it in the shop as a running load will build boost,not a fast engine rpm.
Old 11-28-2004, 08:50 PM
Dodgezilla's Avatar
Make sure you put a tie wrap on the hose because it will blow off with your first trip down the road. Also do the same on the guage side because it's even more of a pain to fix if it pops off...
Old 11-29-2004, 01:16 PM
HighTen's Avatar
While we're asking questions, let me add another.
How do you get the hoses and wires from the engine compartment into the cab so you can hook them up to the gauges? I think I remember something about going through the rubber that's around the steering column? Is this even close?
Old 11-29-2004, 06:28 PM
RamWheelsBy4's Avatar
If you have an auto trans its easy, dont know if this Firewall plug is used on standard trans. On auto it is plastic plug that is held in place with two nuts. Simple to take off and drill what ever size hole is necessary.
Old 11-29-2004, 06:37 PM
HighTen's Avatar
Wow, great pic RamWheelsBy4! Thanks
dodgemaniac
Competition / Pulls / OffRoad
07-31-2008 10:15 AM
coparam4x4
13
01-01-2008 02:31 PM
moparmatt
04-25-2007 02:13 PM
59FORD
04-07-2006 12:28 AM
Quick Reply: Advice for boost bolt location
