99 2500 cummins fuel filter canister leaking fuel
Old 10-29-2009, 03:03 AM
jsmith2260's Avatar
the head of the fuel filter canister is leaking around the heating element and the dealer is the only avenue to get a kit to fix the problem.......$1200.00
any suggetions on a less expensive approach??
any help would be appreciated.
Old 10-29-2009, 08:43 AM
mariner's Avatar
Try phoning around to other sources - that sure doesn't seem right. Methinks that dealer is full of BS and would recommend taking your business elsewhere.
mariner
Old 10-29-2009, 09:07 AM
nickg's Avatar
I think the 2000-2002 are cheaper,and they are a better filter set up compared to the earlier version. and if not call a salvage yard to see if they have one, another avenue is ask in the classifieds to see if any one has one, I know when I installed my Airdog I removed the filter housing and tossed it away.
Old 10-29-2009, 09:45 AM
Purplezr2's Avatar
if you don.t mind ebay
# of them on ebay
Also there is a guy that goes by redlinear on ebay that all he does is part out cummins truck, may email him
Old 10-29-2009, 11:52 AM
aggiebowhunter's Avatar
Mine was doing the same thing awhile back. Removed the cannister and used some epoxy to seal the leak. Same here a replacement was about $1200. Epoxy was $5
Old 10-29-2009, 12:31 PM
rebal's Avatar
replace the oring ...take out the filter head and cut the wires remove the 3 T25 screws push out heater and slip new oring on reverse proses about 1 hour and $1 done
Old 04-25-2010, 02:32 PM
MossyOakCTD's Avatar
I just did this and it was easy and cheap and fixed the issue. THANKS REBAL!
bbran
05-27-2013 11:00 AM
mstep3
09-28-2010 03:29 PM
jsmith2260
10-30-2009 07:25 PM
Jmac
07-04-2005 03:02 PM
NOTSTK
01-03-2005 04:07 PM
Quick Reply: 99 2500 cummins fuel filter canister leaking fuel
