fuel filter canister leaking
Old Oct 29, 2009 | 09:55 AM
jsmith2260's Avatar
99 2500 cummins. Fuel is leaking at the fuel heater and i read that you can replace the o-ring to stop the leak, just wondering how difficult that is and how effective that fix is.
Old Oct 29, 2009 | 12:34 PM
rebal's Avatar
super easy and costs $1 just remove filter head cut wires remove 3 T25 screws push out heater slip on new oring reassemble 1hour
Old Oct 30, 2009 | 06:31 AM
Burrhead's Avatar
I let mine continue to leak (since it only leaked when the heater was on) which was a big mistake. The constant dripping on the starter toasted it.
Did mine back in August when I had to replace the lift pump.
I did not cut the wires though. I removed the wires from the plug so they would snap back in when finished.
The toughest part for me was finding the correct size o-ring. I went to Napa, O'Reilly, ACE hardware, Orscheln farm and home store... nothing would allow the heater plug to slide back into the canister header even coating with oil. Next day went to a local CAT dealer with the old o-ring. 5 minutes and one dollar later I was on my way. For what it's worth, the o-ring I got from CAT was purple color.
Not a drop since and no more mess.
Old Oct 30, 2009 | 07:25 PM
jsmith2260's Avatar
Replaced the oring and put it back togoether and so far ....... no leaks.
Thank you for your help.
mstep3
Sep 28, 2010 03:29 PM
jsmith2260
Apr 25, 2010 02:32 PM
Jmac
Jul 4, 2005 03:02 PM
NOTSTK
Jan 3, 2005 04:07 PM
steveb
Aug 20, 2004 12:48 AM
