5th gear fell off.....
Old Aug 28, 2003 | 01:44 PM
1320's Avatar
Well 5th gear fell off today....what are the options....
Im looking at a quick fix.....is there an updated nut? if so is it worth a dam? And can I atleast get it back together by only removing the tail housing? I did a search but came up empty...
Old Aug 28, 2003 | 03:32 PM
Copenhagenjunkie's Avatar
Re:5th gear fell off.....
Bluementhal's in OKC 1-888-236-4800 ask for Monty and tell him Karl Darby need some more shirts ;D
Old Aug 28, 2003 | 08:28 PM
bulthisl's Avatar
yes there is an updated nut.
Through DC about 40 bucks for kit.
I've been runnin it 2 years.
I work mine pretty hard.
And the tailshaft is all that has to come off.
You will have to tighten to 300 ft. lbs.
: Eddie : 8)
Old Aug 29, 2003 | 10:46 AM
1320's Avatar
47.80 at a local dealer....hhhhmmmmmm300 ft lbs...
I think my IR only goes to 240....or so.......sounds like a 6 ft handle (floor jack) and as tite as it ll go.....and super duty locktite.......
any other recomendations....
Old Aug 29, 2003 | 12:59 PM
Helicopter Dan's Avatar
1320 try to borrow or rent a torque wrench the peace of mind knowing you got it torqued proper will be worth it. Annother idea you might try is Sears buy it use it and then decide if you wanna keep it or return it.
Old Aug 29, 2003 | 06:12 PM
KATOOM's Avatar
Sorry to hear about that. When and how did it happen? Where you towing something or just cruising? Do you tow heavy in fifth? Just wondering cause I would like to keep this from happening to me for as long as possible. ;D
Old Aug 29, 2003 | 11:54 PM
1320's Avatar
I wasn t towing anything....empty @ 75 . I see the problem.....the main shaft is miss designed...the gear itself works the nut loose because of the slack in the splines. I bought an after market main shaft kit....that is splined all the way for 5 th. It will be fixed on saturday......
Old Aug 30, 2003 | 01:00 AM
KATOOM's Avatar
Glad to see you are getting the shaft. How much did it cost and how much is it to install? I was under the impression it was very difficult.
Old Aug 30, 2003 | 10:10 AM
1320's Avatar
I was going to do just the nut....but thats 50$ plus its not really a nut....it takes a special wrench ( I didn t check on a price) but I bet its 30+ $ plus oil etc...and it would be 100$ and my time....but the main shaft kit was 500 and 275 for labor....and I didn t have to spend any f my time doing it....would have taken me all week end........so the 275 was worth it.....just need to get everything else done now....
LemonDodge
Sep 7, 2019 03:51 PM
LemonDodge
Sep 16, 2010 07:33 AM
bigdogtruck
Jan 4, 2007 01:41 AM
97Dually
Nov 20, 2003 01:22 PM
RamDan03
Nov 9, 2003 10:26 AM
