04 5.9 engine replacement
Old Mar 28, 2012 | 06:16 PM
zoomlcmc's Avatar
I am replacing my engine, do I need to replace it with an engine from a 4x4 automatic or that makes it easier?
Old Mar 28, 2012 | 06:22 PM
Dieselbuilder's Avatar
Should be able to use any year just make sure you use your ecm from yours as well as all the sensors and wireing harness...might have to swap injectors but check on that,
Old Mar 28, 2012 | 09:31 PM
Spooler's Avatar
Which engine do you have? Need more info on your truck. 04 has an SO, HO 305/555 and the 325/600 HO engine.
Old Mar 29, 2012 | 09:23 AM
zoomlcmc's Avatar
I have the 325/600 ho motor
Old Mar 29, 2012 | 09:30 AM
Spooler's Avatar
So you have an 04.5. an engine from 04.5 to 07 will work. In the later model trucks you may have to the change over the rocker box, valve cover, and possibly the front cover.
Old Apr 2, 2012 | 01:01 PM
zoomlcmc's Avatar
spooler, you say I may have to change front cover and maybe rocker box? why if I am changing whole motor
Old Apr 2, 2012 | 05:18 PM
Spooler's Avatar
Different electrical connections for the injectors (harness), and different mounts for the fan and shroud.
CTD99
25
May 24, 2005 10:15 AM
451Mopar
Apr 30, 2005 07:36 PM
hauliday
Feb 26, 2005 08:18 AM
jj3500
Sep 16, 2004 08:15 AM
kingofdodge7131
Mar 22, 2003 09:39 AM
