TXDTR #8 Forum for the Texas chapter #8
Tx #8 June Meet
Old Jul 2, 2009 | 09:49 AM
  #226
Duallydog's Avatar
I think what happens on the gear vendors is either people drive that much faster since they dropped rpm or they dropped too much rpm and are lugging the engine (most of them I see drop to 1600 at 70mph). However it may all come down to being more efficient to just throw in the 3.42s and put on a 33" tire that isn't too aggressive.
Old Jul 3, 2009 | 02:40 AM
  #227
TexasCTD's Avatar
Originally Posted by TexasCTD
......................Now, I am also going to be curious about my mileage. I reset my overhead thingy and ran the truck today.......and it said around 25 mpg. Now normally it says 22ish which of course is way high. My actual mileage with the old BFG Muds usually hovered around 15.5 to 16 when I hand calculate, mixed city/highway. So im curious if the new tires really helped my mileage by 3 mpg or even 2. I just filled up tonight (15.5 mpg) on the last tank.........and im headed out to Mississippi empty (no towing) so I should get a nice baseline with the new Nittos. I'd be thrilled with an actual 19 on the road!!
Well it turned out to be (hand calculated) 17.822 mpg running 72 mph with a/c blowing cold (like always). Outside temp mostly around 100-102 degrees today. Drove about 470ish miles and the needle was just under the half way mark on the dial. Overhead said I could go 262 more miles on that tank (but that's a lie). Im a little disappointed actually. But the mileage is what it is. Still prob a little better than the same trip with 35'' muds.
Truck rode and drove awesome though. QUIET.
Old Jul 3, 2009 | 08:37 AM
  #228
bnold's Avatar
Well been a while since I bought a toy for the truck... So I bought a new switch that will REDUCE my power about 50%!! Different isn't it?? lol
Finally bought a valet switch for the ol girl... I have been unhooking my AFC line manually, but that is kind of a pain... Nice when towing heavy not to have all that fuel on tap!! Other times as well... With the AFC disconnected truck tops out at 35psi boost.... Figure thats prolly around 300hp for my rig...
Also picked up another front seal, going to bump the timing up some at some point... thinking 17* or 17.5*, supposed to be a little lower EGTs on the top, maybe even some better mileage... We will see, ready to experiment some... Buck was pretty confident that I was easily leaving 50-75hp on the table with my conservative timing in Alvarado.
Next I need to figure out what is up with my FASS... Sometimes after starting the truck my FASS gets stuck around 1-8 psi... Once I blip the throttle it comes up to 35ish and stays there fine... Just sucks to know that sometimes when I remote start the pump isn't getting much pressure... I would like to get the running pressure up to 50ish as well, I have a new spring that I have been sitting on for a while now... It is supposed to be a 60psi spring, hoping is is a tad lower
Old Jul 3, 2009 | 01:53 PM
  #229
RowJ's Avatar
Pump not getting full pressure.
Maybe just the gauge! Would be easier to believe....... no?
RJ
Old Jul 4, 2009 | 07:41 AM
  #230
RowJ's Avatar
Well it turned out to be (hand calculated) 17.822 mpg running 72 mph ..
I just got 17.2 mpg on a 1000 mile test on my new 35's..... includes some hauling, daily comute and Hwy!
RJ
Old Jul 5, 2009 | 09:18 PM
  #231
bnold's Avatar
RJ
mechanical gauge straight hose... and the idiot light flashes right along...
Old Jul 5, 2009 | 09:19 PM
  #232
bnold's Avatar
Well guys... have about 1hr 10mins before I take the vows!! Wish me luck!
Old Jul 5, 2009 | 10:04 PM
  #233
AggieJustin's Avatar
An hour before the wedding and the man is on DTR. That's dedication.
Congrats Brian!
Old Jul 6, 2009 | 06:29 AM
  #234
elirandolph's Avatar
Congrats Brian
Old Jul 6, 2009 | 08:40 AM
  #235
RowJ's Avatar
Or reaching out for HELP!!
Notice no contact since nuptuals.
PS: Congrats!
RJ
Old Jul 6, 2009 | 08:52 AM
  #236
crobtex's Avatar
Congrats to both of you!
Old Jul 6, 2009 | 10:09 AM
  #237
Duallydog's Avatar
Congrats Brian, and I have to say you are hardcore about being on DTR.
Old Jul 6, 2009 | 12:04 PM
  #238
mattfolsom's Avatar
Not liking this CA thing that much lol I am going to try to get back to PA or TX ASAP!! There is not as much Diesel interest as i thought there would be here either
Old Jul 6, 2009 | 02:30 PM
  #239
XLR8R's Avatar
Why is that? Inquiring minds ........!
Specs that I saved, from a very technical, 2nd Gen thread on TDR, with general concensus from all guru's that comtributed, are.........
- 3.2*L, 3.5*R caster, .3 cross caster....
- 0-.1* toe,
- 0* +/- .1 camber
Pretty close to what you said Mike!
RJ
The weight deflection caused by your hand position on the steering wheel dictates drag link adjustment for correct steering wheel "clocking".
3rd Gens also have 1/10th degree toe-in spec, but any year benefits from an extra degree of caster to help avoid death wobble - especially with a leveling kit.
Congratulations Brian!
... you just got there!
You turning into a Diesel Drifter?
Old Jul 6, 2009 | 10:20 PM
  #240
PS: Congrats!
RJ
If he had been on DTR right after, I think he might have been needing help when Amy found out.
