TXDTR #8 Forum for the Texas chapter #8
February Meet will be in Alvarado, TX
Old Jan 23, 2008 | 02:03 AM
  #61
bsj04's Avatar
Originally Posted by RowJ
Buck, Looks like Friday night will work. Let us know if you can work it out. Four definite with Big Blue a maybe.
My best guess would be half a dozen min. when the time comes... plus any you have that might be interested??
RJ
there is a guy i work with that has a d-max and was wanting to put it on the dyno. so if noone cares if a d-max comes he would probaby be up for it also.
Old Jan 23, 2008 | 07:23 AM
  #62
RowJ's Avatar
More the merrier!
RJ
Old Jan 23, 2008 | 09:17 AM
  #63
HT3500's Avatar
Hey guys Friday night is a go, I put up a thread, 5p.m till 10p.m or so maby longer hope we get a bunch, should be fun anyways...Sorry no mobile dyno so hope this works...
Old Jan 23, 2008 | 09:34 AM
  #64
RowJ's Avatar
Thanks Buck for setting it up....and for the great price!
Thread here for those interested....
https://www.dieseltruckresource.com/...=1#post1905990
RJ
Old Jan 23, 2008 | 09:42 AM
  #65
bnold's Avatar
Sorry I missed the B-day gifts!
Here's mine:
Dont know how much longer they were going to last!!
In in for dyno Friday before, sounds like fun! Hopefully break 600 on that dyno!
Old Jan 23, 2008 | 09:44 AM
  #66
bnold's Avatar
And I think the Jetta faired pretty well for box truck at highway speeds!! Driver and front passenger looked like they were in great shape!
Hate to say it but the Dodge hasn't been started in over a week now! (Mainly because it needs somebody to fill the tank! )
Old Jan 23, 2008 | 09:55 AM
  #67
crobtex's Avatar
Here's mine:
(Pics deleted)
That's scary! Looks like a really good present to me.
Hmmmm....I may bring the Starcraft camper.............with a "For Sale" sign on it.
Old Jan 23, 2008 | 10:03 AM
  #68
XLR8R's Avatar
Wow Brian - haven't seen one of those random-angle roller bearings for a while... I heard they run smoother with a high-tack lube!
Old Jan 23, 2008 | 11:04 AM
  #69
RowJ's Avatar
WOW is right. Scary!
Dan, Did Kerri say it was making a bit of noise when she shut it down. Would bet it could be heard a ways away!
Brian, How bad was the nut? Need help?
RJ
Old Jan 23, 2008 | 11:12 AM
  #70
bnold's Avatar
I needed a big pry bar to put between the lugs to even turn that thing! It was locked down!
THe nut wasn't too bad to take off... I was sick of those **** thru hub wheel caps by the end of the project though..
1. Break lug nuts
2. jack up truck
3. remove lug nuts and wheel
4. remove center cap
5. Reinstall wheel
6. tighten a few lug nuts
7. place truck on ground
8. bounce on end of 6' pipe until nut breaks loose (curse when pipe hits ground and smashes finger! )
9. Jack truck back up
10., remove wheel all over again
11. finally get to work on bearing!!!!
12. Repeat 10-1! Stupid thru caps! lol All Ryans fault too!
Kerri said it was making a good bit of noise and getting harder to steer... Ya I bet... It took a few tries (on separate days) to get the truck straight in a parking spot cause the power steering wasn't strong enough to overcome the drag of the bum wheel!! Ya that could have been bad!
I was impressed at the impressive pile of molten metal shavings that collected on the knuckle!! Wish I would have snapped a pic of those!! It was a good sized clump!
Old Jan 23, 2008 | 11:21 AM
  #71
hotdram's Avatar
That's OK. My b-day is in July, you can give me the same thing
~Rob
Old Jan 23, 2008 | 11:23 AM
  #72
bnold's Avatar
Hmmm it was like low 70s that day, doubt I would have the same work environment in July!!
Old Jan 23, 2008 | 03:41 PM
  #73
RowJ's Avatar
I replaced both wheel bearing assemblys 15,000 miles ago and am again getting an rpm rubbing noise from the drivers side on sharp right hand turns??
Can you think of anything else that would sound like that, cause I can't??
Old Jan 23, 2008 | 04:29 PM
  #74
Diesel-Dan's Avatar
Tire rub? Look for buffing on your inner fender wheel well....
WOW....That is a bad bearing.......i might be doing my other side here in a few months just for S&G's.
Again...thanks for the help Brian!
Old Jan 23, 2008 | 09:09 PM
  #75
BBA's Avatar
BBA
I have to change my left front hub bearing. I was going to have a place in town do it but the wanted like a little over $400 to do it!
