TXDTR #8 Forum for the Texas chapter #8
DTR #8 September/October 2010 Thread
Old Sep 22, 2010 | 05:25 PM
  #31
Duallydog's Avatar
Thanks Tater
Old Sep 22, 2010 | 11:16 PM
  #32
TexasCTD's Avatar
Going to Crandall-----
Robert
Justin
Rowland
Eli
Blowinsmoke
Kurt
93-12smoke
Prob NOT going to Crandall---
Matt
Max
No word yet on going to Crandall-----
Mike????
Charlie????
Rob????
Brian????
Any body else???
Is anybody going to "participate" in anything at Crandall?? I think they are having a Dyno, Sled Pull, and Drags. I'm considering the dyno (with new injectors now) and maybe some drags......but wish'n I had more turbo. (I thought I would by now, but $$$ priorities keep getting in the way)
Old Sep 23, 2010 | 08:54 AM
  #33
AggieJustin's Avatar
Considering my setup hasn't changed power wise in a couple of years, not much use in me hitting the rollers. So I'm just going to be a spectator.
Old Sep 23, 2010 | 12:20 PM
  #34
RowJ's Avatar
Ditto
Old Sep 23, 2010 | 10:23 PM
  #35
03RAMBUNCTIOUS's Avatar
I watch wind blow...
count me out.. Have fun snap photos!.
I really want to make it down to NM and get on the same rollers and see how the Flux's, turbo, Dr. P box, exhaust helped me out. I am surely above the previous 446, 1119.
Old Sep 24, 2010 | 08:17 AM
  #36
bigredBCS's Avatar
I'll be there. Might bracket race and do the show and shine.
Old Sep 24, 2010 | 10:20 AM
  #37
Does anyone have any ideas where to pick up a Schrader valve like the ones used in the stock fuel system? I need one with a male 1/8" NPT fitting on the back. There were a couple included when I bought my fuel pressure test gauge, but they've managed to disappear or stay attached to trucks I've tested over the years.
I think my electric fuel pressure gauge is dying on me. I've been seeing higher than normal pressures lately (20idle, 18 driving, 16 pushing hard) and I don't think my LP got stronger in its old age. Then I noticed this morning that with the engine and LP off, but the key on, I'm seeing about 3psi on the gauge. And I doubt the fuel system is holding pressure.
I just wanted to put my test gauge on it to check the readings when I realized I didn't have any Schrader valves to put into my test port.
Old Sep 26, 2010 | 07:15 PM
  #38
bnold's Avatar
I'm a no for Crandall
Old Sep 26, 2010 | 10:21 PM
  #39
TexasCTD's Avatar
Well I dodged a bullet tonight......with my transmission....that is. I was on my way home from work and my trans quit shifting beyond 2nd. I could push the accellerator and nothing......it wouldn't do a thing over about 40-45 mph. It was like it was coasting until it got down below say 35 mph and then it would grab and go again....until 40-45ish, again.
Eventually, I called Rowland to see if he had any tips or had experienced anything like that with his DTT. And I had also called James Northum and left a message.
I limped the truck home in the far right lane of 75 and flashers on at about 40 mph. James called back and after I gave him the codes he thought it might be my "transmission rpm speed sensor". Thankfully, Ghettozone was still open and had the replacement part. I put it in a couple of minutes and it road tested good as new. The old one was cracked. Anyway, thankfully the Black Beast lives on for now.
Thanks Rowland for your input and a big Thankyou to James Northum for diagnosing a quick (AND CHEAP $20.00 part!) fix over the phone.
Old Sep 26, 2010 | 10:24 PM
  #40
TexasCTD's Avatar
Robert
Justin
Rowland
Eli
Blowinsmoke
Kurt
93-12smoke
Schoolbus
Matt
Max
Brian
Mike????
Charlie????
Rob????
Any body else???
Old Sep 27, 2010 | 02:05 PM
  #41
bnold's Avatar
Anybody been over here? https://www.dieseltruckresource.com/...t272778p3.html
I'm at a loss...
Old Sep 27, 2010 | 02:14 PM
  #42
Diesel-Dan's Avatar
Subscribed
Old Sep 27, 2010 | 07:12 PM
  #43
bnold's Avatar
Can't believe there is no action on that thread
Old Sep 27, 2010 | 09:06 PM
  #44
shocked
Old Sep 29, 2010 | 08:39 AM
  #45
crobtex's Avatar
Originally Posted by AggieJustin
The nice surprise was how much better the Bilstein 5100 shocks (silver/black) perform over the Bilstein HDs (yellow/blue) that I had in there. The bumps and holes on 75 used to be a jarring hit on the front end, now they are just a gentle bump.
What is the difference besides the yellow tube and the zinc tube? Looks to me like the same shock except the paint vs the zinc..............
Also, where did you get them?
