TXDTR #8 Forum for the Texas chapter #8
DTR #8 April Meet in Ennis
Old Mar 26, 2008 | 08:51 AM
  #31
RowJ's Avatar
Originally Posted by AggieJustin
... to keep you from becoming a pole vaulter instead of a sprinter.
Good one.......That's it exactly. In case front mount breaks from launch pressure. (never seen it or heard of it but must have happened to cause regulation.)
Available at LazarSmith.com.
RJ
Old Mar 26, 2008 | 09:15 AM
  #32
Duallydog's Avatar
https://www.dieseltruckresource.com/...d.php?t=197071
Hey guys, got a truck you've seen at the pulls up for truck of the month. He's also one of my crew, so don't hold that against him.
Old Mar 26, 2008 | 10:29 AM
  #33
LFD2037's Avatar
Originally Posted by TexasCTD
LFD....You firemen have it made! Can't you trade out a shift with another guy? Surely a "B" shift guy can work for ya and you work his, no?
Yeah, but I just swapped the 30th for a wedding. I'm gonna see what I can do. I need to ride in a couple of yall's trucks w/built tranny's to give me the final push to just get mine done.
Old Mar 26, 2008 | 12:48 PM
  #34
TexasCTD's Avatar
RJ
I looked at Mike's website again...but I guess he doesn't have a pic of the "retaining straps". http://www.lazarsmith.com/tractionbars.html
This extra addition needed for Ennis has kinda caught me off guard.
We just installed my traction bars last Saturday.
Old Mar 26, 2008 | 01:19 PM
  #35
TexasCTD's Avatar
My guess is that they are straps to hold your traction bars up in case they break to keep you from becoming a pole vaulter instead of a sprinter. Same with the driveshaft loop.
Guess so Justin! I doubt Mike's brackets are going to fail...but im sure that not all TB brackets are made quite like his either.
Old Mar 26, 2008 | 01:21 PM
  #36
bnold's Avatar
Your brakets look like a different design?? Front mount is not as close to the frame?? Why???
Old Mar 26, 2008 | 01:31 PM
  #37
TexasCTD's Avatar
New and improved? Honestly I don't know. Maybe Mike will jump in and explain. Probably some slight differences between the 2nd gens and 3rd gens.
Also our shock mounts on the rear axles can cause a slight clearance problem if the angle was any higher, so by making the front mounts lower..I am guessing that helps with that some.
Old Mar 26, 2008 | 01:46 PM
  #38
bnold's Avatar
Huh... cool... Looks great by the way!! if you ever bring chrome crap back to that truck we wont speak any more! k? lol
Old Mar 26, 2008 | 05:31 PM
  #39
XLR8R's Avatar
Originally Posted by bnold
Although I hate it when they want to drive my truck!! I'm like dude my clutch is going to snap ur little leg like a twig! (dude last time was about 5 foot nothing couldn't have weighed more tha n 120lbs, He said it was policy, whatever I told him I was riding with, one good push on the clutch and we switched spots!! was pretty funny!)
When I brought my truck to inspection, the tech-dude opened the door for the test drive, took one look at all the gauges, switches and billet aluminum and asked if I minded driving for him... so I took him for a little ride!
I still laugh every time I think of him saying "ok, now try the brakes... OK, slow down for this turn, alright - hit the brakes OK - STOP !" as he white-knuckled the !OH CRAP! handle.
Old Mar 26, 2008 | 05:45 PM
  #40
XLR8R's Avatar
Some sanctioning bodies at some events require safety straps for traction bars, so we have the stainless steel aircraft cable restraints to pass tech where needed.
If a bracket or heim were to drop onto the ground, the bracket's skid plate (thanks Brian! ) or the heim's nose could only slide along the surface due to the shallow angle caused by the bars length... although if you were racing over a curb or across a cattle guard at speed with a dropped fore-end it might not be pretty!
10-4 on the new & improved design; there've been a bunch of running changes on the production pieces over the last year to fine tune materials availability, work flow in the shop, fit & finish, ease of installation and track-side adjustment. I think we're up to a couple of dozen design iterations away from yours Brian - but still none that work better!
Old Mar 26, 2008 | 05:51 PM
  #41
DG527's Avatar
I'll second that!!! I should have become a Fire Fighter! I can't believe I decided on police work.
Old Mar 26, 2008 | 06:30 PM
  #42
crobtex's Avatar
Does the Denton PD still have their drag car?
Old Mar 26, 2008 | 06:54 PM
  #43
DG527's Avatar
Don't know...I work in Coppell.
Old Mar 26, 2008 | 07:04 PM
  #44
crobtex's Avatar
Ooops! I saw Denton and .............
Old Mar 26, 2008 | 07:28 PM
  #45
DG527's Avatar
I live in Denton, I can't afford a house in Coppell.
