TXDTR #8 Forum for the Texas chapter #8
DTR #8 April Meet in Ennis
Old Apr 8, 2008 | 08:54 AM
  #181
bnold's Avatar
Originally Posted by elirandolph
So was it his inj pump that was causing him grief? he told me he thought he had a weak cylinder. I hope it was just the pump.
had compression checked and was apparantly even across the board... Injectors were sent out and checked out fine... Not much left to change out.
Old Apr 8, 2008 | 09:29 AM
  #182
XLR8R's Avatar
Originally Posted by bnold
Wont make this one guys... Can't stomach the idea of driving 500miles for a dyno... Save that $ and run at Ardmore in 2 weeks...
Sounds like a good event though... BigBlue should have his new VP on by then.. See where that gets him..
Maybe you could hitch a ride with someone else?
I hear there's plenty of folks heading past us from Oklahoma way to get to Buda... I'm planning on riding with somebody.
Originally Posted by bigredBCS
And mike, how would carrier bearing shims benefit my truck?
On man oh man Scotty - those bad boys are guaranteed to knock at least 3/10 from your timeslip!
Plus, if your rear end is lifted up, the carrier drop will keep your shaft joints from knockin'... I know I seen how far up your rear was, but I reckon I must've scrubbed that image from my brain since then!
Old Apr 8, 2008 | 12:08 PM
  #183
hotdram's Avatar
Paddle faster, I hear banjo music
~Rob
Old Apr 8, 2008 | 12:56 PM
  #184
03RAMBUNCTIOUS's Avatar
I watch wind blow...
Brian, i am sure i could make room in the red roadster if your interested.
Old Apr 8, 2008 | 02:07 PM
  #185
bigredBCS's Avatar
Thumbs down
so I'm having a great day...
I'm stranded in the middle of a field in bfe Oklahoma with two holes the size of golf ***** in my trans pan...the closest pan is over 4 hours away...
I guess oklahomans like to throw old 6 cyl engine blocks in the middle of fields...
Old Apr 8, 2008 | 02:21 PM
  #186
XLR8R's Avatar
That sux - figures the waste engine blocks would miss your skid plate!
Can't you just weld up the pan? Where in OK?
  #187
bnold's Avatar
Oh man sorry bout the bad luck!
Old Apr 8, 2008 | 02:22 PM
  #188
bnold's Avatar
Appreciate the offer, going to make some money this weekend instead...
Old Apr 8, 2008 | 02:28 PM
  #189
crobtex's Avatar
Crap! Sorry about the trouble.
Old Apr 8, 2008 | 03:00 PM
  #190
Diesel-Dan's Avatar
Hmmm platinum??
I'll try and wire up a schematic for the switch tomorrow.. Will be really easy...
Here.....this is his harness......
Just put a swith on Pin #85 and you should be good.....
File Type: pdf
Old Apr 8, 2008 | 04:04 PM
  #191
Duallydog's Avatar
Wow, that's great. You got to be careful about what they throw in the fields in Okiland.
Old Apr 8, 2008 | 04:11 PM
  #192
RowJ's Avatar
Originally Posted by Duallydog
....got to be careful about what they throw in the fields in Okiland.
My mind is reeling with possible comebacks to that line!
Scott - At least it was the work truck...not the Schoolbus......right?
RJ
Old Apr 8, 2008 | 08:02 PM
  #193
bigredBCS's Avatar
well we got the work truck back up and running... 6 hours later
The two closest pans were in amarillo and shawnee, luckily another one of my dads crews was working down close to shawnee so he brought it over to me here in elk city.
What kind of transmission is in a 3/4ton 2004 hemi 4x4? It has a screw on filter inside the pan??
Old Apr 9, 2008 | 12:16 AM
  #194
TexasCTD's Avatar
Sorry to hear about your bad luck today Scott. That sux.
I think the trans is called a 45RFE or something similar to that.
At least this was the work truck and not the "schoolbus"! Good luck in Buda!
Old Apr 9, 2008 | 04:12 PM
  #195
bigredBCS's Avatar
so who all is making the trip to buda
