TXDTR #8 Forum for the Texas chapter #8
December GTG at the Shop!
Old Jan 12, 2009 | 11:50 AM
  #331
Diesel-Dan's Avatar
Originally Posted by RowJ
Probably dumb question but.... I thought the timing gear came out completely?
But it appears to drive the P-Pump... correct? Drives the Delivery valves???
RJ
Sorta.....just think of the p-pump like a small engine more or less......it has a crank shaft, pistons, and such........and it has to take mechanical input from the geartrain (Like the VP) to do its job. BUT unlike the VP-44...the P-Pump is purely mechanical....not a Hybrid like the VP.
The delevery valves are like a restrictor plate for the injectors...they limit or allow a certian amt of flow comming from the P-pump.....and are located direct on top of the pump...real easy access.......
O yeah...brian....i have a brand new, never used (Other than the pump gear puller) Blue-Point 12 Valve Timing Set that you might find useful......ill take a loss on it if you are intersted.....
Old Jan 12, 2009 | 05:23 PM
  #332
bnold's Avatar
Appreciate the offer, but I have a brand new Miller timing kit that I used...
Snap on and Millers kit is the same except the Snap on kit comes with a gear puller and no barring tool and Millers kit comes with the barring tool and no gear puller Luckly my custom special puller works on the P7100 gear as well!
Old Jan 12, 2009 | 05:26 PM
  #333
bnold's Avatar
Originally Posted by crobtex
Great job! I've been wondering when the conversion would start. I have a few questions, but will save them for later.
I'll answer what I can! Still learning
Old Jan 12, 2009 | 05:30 PM
  #334
bnold's Avatar
Some members will do anything to avoid buying a new VP-44!
Sounds like the cost, after parts sale (including the Adrenaline), will work in your favor... but had to be the curiosity factor and a labor of love!
Nobody would go that far just to get rid of an electronic injector pump.
What Plate you running? Expecting more smoke in warmer weather?
Great pics. Looks like the usual (from Brian) top notch job!
RJ
Definitely been curious about the 12V pumps for quite some time, but wasn't ready to give up all the work on my motor and truck to find out! Definitely don't need 2 trucks and a car so maybe this will scratch the itch! ... Plate in there is a stocker for now, probably steal one from Dan...
Right now I have less haze at idle than I did with the Mach 6.5s, but I am expecting more smoke overall
Old Jan 12, 2009 | 05:31 PM
  #335
XLR8R's Avatar
I would love to give that a nice home!
How much of a loss can you take?
Old Jan 13, 2009 | 12:56 AM
  #336
Tate's Avatar
Take it to the grinder and make it flat. If you're running an AFC, the lower profile doesn't really matter anyhow.
Old Jan 14, 2009 | 02:49 PM
  #337
RowJ's Avatar
...Right now I have less haze at idle than I did with the Mach 6.5s, but I am expecting more smoke overall
You are running 7 X .014 injectors. Daniel has 5 X .018.
Educate me, please. I know it's all about cc of fuel flow and I have read that .025 is about max for racing?
What does the first (both actually) numbers mean?
RJ
Old Jan 14, 2009 | 03:24 PM
  #338
Diesel-Dan's Avatar
RJ
7 holes at 0.014" diameter each would be my guess.....
Read this post...very informative....its more towards 1st gens...but....
https://www.dieseltruckresource.com/...87&postcount=2
Old Jan 14, 2009 | 03:48 PM
  #339
RowJ's Avatar
Thanks.......... Good read. No 7 holes listed? Is that a 2nd Gen 12v thingy?
Guess it wasn't till the 24v's that builders realized that 8 holes is optimal?
Maybe 12v's have different piston top configuration.... Brian??
(I'm constantly amazed by how little I know about 12v's)
RJ
Old Jan 14, 2009 | 04:39 PM
  #340
XLR8R's Avatar
Daniel's truck ought to have about 15-20% more nominal fuel flow throught the sticks... Brian's truck "should" be more efficient at low & medium RPMs.
Anyways, what's the difference when you're UnderValved?
Old Jan 14, 2009 | 06:09 PM
  #341
bnold's Avatar
RJ
Yep what Dan said... 7 holes and 14thou each... Who says 8 holes is optimal? My 6.5s were 7
Old Jan 14, 2009 | 06:43 PM
  #342
bnold's Avatar
Yep his should flow about 15% more than mine...
the 7 holes should be a little more efficient...
Different injectors for different uses...
Old Jan 15, 2009 | 07:07 AM
  #343
RowJ's Avatar
Maybe not optimal.... but maximum.
Don M told me he had tested up to 11 holes and found anything more than 8 was counter productive. (maybe just no more productive?)
RJ
Old Jan 16, 2009 | 08:00 AM
  #344
RowJ's Avatar
Listed on DHRA's website!!
DHRA cancelled all 2009 events and is closing down the organization.
Anyone surprised??
RJ
Old Jan 16, 2009 | 08:25 AM
  #345
XLR8R's Avatar
I've been saying this would happen since early last season... don't worry though - no doubt they've already applied for a bailout with our $$$. Hey, Big Diesel is too big to fail, right?
