TXDTR #8 Forum for the Texas chapter #8
April Meet at The Ranch
Old Sep 12, 2010 | 09:37 AM
  #586
AggieJustin's Avatar
Originally Posted by RowJ
Been using a Futo drain (from Geno's) for 3-4 yrs. Love it also,but......
I run one qt of oil through the system before closing the drain.
Reason - these drains leave a bit more dirty oil in the pan. One clean qt seems to clean the dirty out a little better!
RJ
I read that same concern when I was doing some searching before I bought the valve. I even saw where some people drilled some holes at the top of the threads to allow more oil to drain. I was going to do the same on mine to get a full drain, but once I measured I realized that the threads on the plug were slightly shorter and the depth of the drain hole. Not sure if they shortened the threads on the newer valves because of customer feedback, but retaining more oil doesn't appear to be a problem anymore.
Old Sep 13, 2010 | 11:12 AM
  #587
RowJ's Avatar
Originally Posted by AggieJustin
.... but retaining more oil doesn't appear to be a problem anymore.
Sounds good!
I found drain hole is not the low point in the pan. I would add 1 clean qt before replacing plug even if did not have Futo Drain. I experimented with this before I added Futo and found my oil stayed clear for 700 miles by doing the extra qt!
Did everyone get the E-mail on NADM's Diesel Shoot Out on Oct 9th??
I'm going. but I won't be racing my truck anymore.
My DTT finally needs a rebuild after 280 1/4 mile passes and 200,000 miles.
My Tq Converter was slipping and showing sighs of wear and tear.
Rebuilding it instead of replacing with a triple disk to save $600.00.
And since the higher grade of friction material they use to use is no longer available, I limited to maybe 500 hp towing power.
RJ
Old Sep 13, 2010 | 11:58 AM
  #588
Sounds good!
Maybe I'll have to start doing this. It can put my extra quart I always have left over to good use.
It's on my calendar and so far it looks like I can make it as well.
Old Sep 13, 2010 | 09:48 PM
  #589
TexasCTD's Avatar
Let's kill this 5-6 month old thread and put it out of it's misery!
Here is our new one.........
https://www.dieseltruckresource.com/...html?p=2840521
Don't forget about the NADM event on Oct 9th!!
crobtex
TXDTR #8
400
Mar 8, 2012 01:16 PM
iker42
Apr 22, 2006 04:54 PM
Geico266
Apr 8, 2006 08:44 PM
shortround
Apr 29, 2005 04:08 PM
AlpineRAM
Apr 13, 2003 05:11 PM
