Wind deflectors for 5er pulling ?
Old Sep 4, 2005 | 08:23 PM
Superduty's Avatar
Who is using them ? Which models, why and how are they working ?
Which ones don't work ?
How much difference do they make ?
How much are they ?
Anyone make their own ?
Are these any good ? http://www.wingmaster.com/rv.php
Old Sep 5, 2005 | 08:02 AM
The Domie's Avatar
I asked the same questions a while back on the rv forums and the general consensus was that they are real a great bug screen but are not any good for improved mpg.
Old Sep 5, 2005 | 08:33 AM
pappyman's Avatar
I had a Turbo Wing on my truck....It would help some if your in a head wind....as far as any mileage gain maybe 1 MPG is all I would see.....most trailers do a good job of wind deflection by design so a added wing doesn't help much
Old Sep 5, 2005 | 08:39 AM
nailzsn's Avatar
In my photo gallery, you will see a large wind deflector that I bought from a friend of mine. I have a 30ft, 10,000lb, high fifth, and towed it from NW Ohio to Arkansas last year with the deflector. I got 12.5 to 13.5. Since that was my only trip with the truck, I have nothing to compare mileage without it, but my brother-in-law was getting 9 with this powerstroke.
I bought a smaller deflector (since my son, who generally helped me put on the deflector is moving out) and only had a 200 mile trip to Indiana. It only got 11.5, but, like I said it was a short trip.
All mileage hand calculated. I originally was going to cut down the large deflector so that I could handle it by myself, but got the other one instead.
By the way, if you are close to Ohio, I could make you a good deal on the large deflector.
Old Sep 5, 2005 | 09:49 AM
Superduty's Avatar
I like the dark blue deflector in your gallery. Is that custom made or from a highway tractor ? I've heard the "3D" deflectors are much better than the simple wings, especially in a side wind.
Old Sep 5, 2005 | 05:03 PM
Casey Balvert's Avatar
I have one. On my last rig which had a flat front it gave me about a half mile to the gallon and it did make the rig more stable in cross winds. This trailer is rounder in the front and I don't notice much of a difference.
Old Sep 5, 2005 | 07:57 PM
nailzsn's Avatar
Superduty,
The deflector is actually emerald green - that matched my friends truck. It is a defector from a highway tractor, I believe. The racke that it mounts too is made out of about 1 3/4" square tubing. There were holes in the rack that bolted to some fixtures in the truck's bed rail holes. Since my friends truck was about a '99 model. Since the bed rail holes on his truck did not match mine, I added some tubing under the rack rails (for added height too) until I could get a change to re-weld it together for a better fit, but I never got around to it.
As far as stability, it definitely felt stable since it is much taller than the small deflectors.
Old Sep 7, 2005 | 11:19 AM
Superduty's Avatar
nailzsn: Do you know what model of highway tractor that deflector came from ? I'm thinking it is the upper deflector from the FL112 tractors with a day cab ?
Old Sep 7, 2005 | 11:37 PM
ASHNBAK's Avatar
How much are they ?
This is were I purchased my wing, the AEROTRAVEL III. I absolutely notice the difference in stability, especially in an off center head wind, cross wind, or when driving next to a big rig. Towing with 2500 Yukon XL, trust me! Can't speak for the mileage because I don't drive with any regard for obtaining good mpg.
Old Sep 8, 2005 | 05:52 AM
nailzsn's Avatar
superduty:
I am not sure what model it came from since I got it from a friend who had the frame made to fit his dodge. I do know that if someone was close enough to pick it up, it could go with them for about a 100; which is significantly less than I paid for it.
Old Sep 8, 2005 | 10:38 AM
HiJenks's Avatar
How much are they ?
I got a Ultra Trail-Eze II 5yrs ago at Camping World, It's a universal bed mount,automatic angle adjustment (varies by speed) and I got it for my W150 gasser. It cut Rpms 250 pullling a 22' 5r high profile.
I use it on my 98.5 pulling a 40' triple slide High profile and it dropped 200 Rpm at 70. I like the mounting ease, it mounts through the front stake holes and has given no trouble.
RenegadeT
13
Jun 20, 2025 03:24 PM
06RAMCTD
Dec 26, 2006 01:38 PM
grantx5
Dec 25, 2005 06:15 PM
Diasiobob
Mar 28, 2005 07:19 PM
turbo59pwr
Jun 11, 2004 07:45 PM
