Vehicle lighst stop working when I hook up a goose neck or bumper pull trailer
Old Apr 19, 2011 | 10:58 AM
Jessie's Avatar
Unhappy Vehicle lighst stop working when I hook up a goose neck or bumper pull trailer
I have a 2003 Dodge Dually 3500 and when I hook up either my goose neck or a bumper pull, the turn signals on both vehicles sometimes quit working. When I unplug the trailer the turn signals on the truck start working just fine.
Old Apr 19, 2011 | 08:42 PM
grouch's Avatar
The first thing I would do is check the wiring on the vehicle side of the connector. Do the lights do this if you hook it to someone elses trailer? The common denominator on your problems is the vehicle. My gut feeling is you have a ground problem somewhere in the connection.
Old Apr 20, 2011 | 01:56 PM
Foxborough's Avatar
I ran across the same problem.
Just to verify the problem I ran a ground wire from the trailer ground to the car battery and everything worked. It was either the plug to truck ground or the trailer to plug ground, I can't remember. good luck.
Old Apr 20, 2011 | 04:20 PM
02raptor's Avatar
Like Grouch said. Try another trailer but i'm guessing you have a short in the trailer. I encountered this not to long ago.
Old Apr 22, 2011 | 08:48 AM
Jessie's Avatar
Electrical Problem
Thank You, appreciate your advise, I will definitely check it out.
Old Apr 22, 2011 | 08:51 AM
Jessie's Avatar
Electrical problem
Thank you, for your advise, today I pulled a different trailer and no problem, it must be something with the two trailers I had the problems with.
Old Apr 22, 2011 | 08:54 AM
Jessie's Avatar
elecrical problem
Thank you, for your advise, today I did pull a different trailer and no problem, it must be something with the two trailers I had the problems with. Thanks again.
Old Apr 22, 2011 | 08:57 AM
Jessie's Avatar
electrical problem
baskhana
May 2, 2011 11:05 PM
jethroish
Oct 12, 2009 11:04 PM
mj007
Feb 21, 2008 03:14 PM
Big Horn
Aug 27, 2007 08:49 PM
USMC64-70
Dec 22, 2002 08:07 PM
