Trailer Tires
Old Jun 18, 2008 | 03:15 PM
samboats's Avatar
Trailer Tires
Is it true that the only thing you have to do to make the mobile home type axle 50 state legal is make sure the tires are not for mobile home use???
Old Jun 18, 2008 | 04:47 PM
LFD2037's Avatar
I don't know, but I do know they are not meant for alot of miles.
Old Jun 18, 2008 | 08:22 PM
badme's Avatar
Use any axle you want, but the tires have to be trailer tires to be legal. Car tires and mobile home tires are not acceptable.
Old Jun 19, 2008 | 05:51 AM
chaikwa's Avatar
What he said! Also, if the axle is rated for more than 3000 lb's, it needs to have brakes too.
chaikwa.
Old Jun 19, 2008 | 06:40 AM
ajpulley's Avatar
This might sound dumb, and I'm sure there's a reason, but I just don't know the answer. Why can't the trailer axle be passenger tires of the correct load capacity? That's what 1/2 ton pickups have.
The brake requirement is governed by each state, and is different in each. Sure would be nice if every state had the same laws for axle weights, combination lengths, oversize dimensions, etc.
Don't shoot me for this statement, but personally, if it was up to me, everyone who towed any kind of trailer would have to have an endorsement on their passenger license. I have a Class A CDL, and have my reasons. But, I'm sure others would disagree, which is AOK. Hmm... maybe I'll do a poll.
Old Jun 19, 2008 | 11:25 AM
rich's Avatar
well i run the same tires on my trailers that i used to run on my early dodges and they are a 10 ply and dont say anything about wether or not they are for trailers. been stopped at the coops for level1 and 2 inspections and dang if those troopers didnt say a word about my tires be specific for a trailer. believe brakes are required for 6k and up
Old Jun 19, 2008 | 04:17 PM
chaikwa's Avatar
This is something I don't know the answer to. I think I could find out if someone is REALLY interested. Seems as though that if the capacity of the tire was compliant with the load being hauled, it would be fine. I've seen manufacturers use regular tires on new trailers, so there's either no enforcement or no actual law.
That's only partially true. Any state can make a federal law/rule/mandate more restrictive, but they cannot make any consessions to one that would compromise the integrity of the original intent. And right now, as far as I know, the Fed's, aka; NHTSA and DOT, require brakes on any axle and/or trailer that will exceed 3000 pounds capacity.
chaikwa.
Old Jun 19, 2008 | 04:35 PM
RickCJ's Avatar
The tires have to be rated higher than the trailer gvw. Yes you can use car tires on a small trailer, but they have soft sidewalls and will rip making sharp turns. Small trailer tires are marked for trailer use and large trailer tires are 6-8-10 ply rated. they are marked LT for light truck and trailer.
Old Jun 19, 2008 | 08:11 PM
badme's Avatar
Legally they have to be LT or marked for trailer use. You cannot use car tires on any trailer. Does anyone check them? who knows I have never been checked.
Old Jun 19, 2008 | 08:14 PM
willysrule's Avatar
it all depends on your state regs...
Old Jun 19, 2008 | 08:36 PM
badme's Avatar
Wrong. Unless you are in the state of Maine or Florida all of the other states have adopted the Federal DOT standards. The state of Maine should have them adopted by the end of the year. That will only leave Florida that lives in their own little world with their own rules.
Old Jun 19, 2008 | 09:10 PM
RickCJ's Avatar
small trailer under 3000gvw doesn't have inspection. no one checks the tires
Old Jun 19, 2008 | 09:43 PM
ajpulley's Avatar
...but they have soft sidewalls and will rip making sharp turns.
Doesn't sound any worse than, again, a half ton pickup, stopped in a parking lot and you turn the steering wheel without moving.
Ok, where would I be able to read it for myself?
Old Jun 19, 2008 | 09:53 PM
DryCreek's Avatar
Wow!
What a lot of BAD information here!
Car tires can be used for trailer applications - they are just de-rated 10% for the axle rating! Although they are legal, it is true that they do not hold up as well due to fewer sidewall plies. The lack of sidewall stiffness also lends itself to induced sway. Not fun.
The 14.5" mobile home tires ARE rated for LOTS of highway miles! Them rascals are as about as durable a tire as they come. Many are 10 ply or better, and being that they are bias-ply, they can take a lot of abuse.
The axles and tires (and all other running gear) are actually the property of the delivery company! Want to keep the axles and running gear when your new home is delivered? Just ask, they'll sell them to your for what they paid for them. I know a lot of folks here that have used them to make 8 and 10 roll hay dollies. Most of them are rated for 8K (with brakes) or 7K (idler). Check the Dexter Axle web page for more specifics.
http://www.trailermanufacturersassoc...ntissues1.html
http://www.nhtsa.dot.gov/cars/rules/...trailer002.pdf
Old Jun 20, 2008 | 08:22 AM
badme's Avatar
near the bottom is says the trailer must be labeled with the tire specifacations.
Under tire size is where they get you. A car tire is not labeled or sized like the label will say.
