question with towing on 2500
Old Nov 26, 2007 | 11:55 AM
shorthair's Avatar
Where're you guy's finding such heavy trailers my last 45' skateboard only tiped the scales at about 8,400# & it was rated to haul an additional 84,000# cargo.
Old Nov 26, 2007 | 12:48 PM
dodgecbr600rr's Avatar
I would only haul that much weight a very short distance doing all back roads. I would diffidently not do that much weight on my 2500 for more then acouple miles. Even if u had a dually i still think it would be over weight. Just my 2 cents.
Old Nov 26, 2007 | 05:46 PM
95turbo4wd's Avatar
about the medical card. i currently drive truck for a construction company , lowboy trailer hauling heavy equipment... i have my cdl a and my medical card, i just put a deposit on a trailer... 04 belmont 26" with beavertail 14k gvw also has the additional deck on the gooseneck... who knows what ill use that for!
got it for $3600 with a new inspection... not bad.. now i need a gooseneck hitch and a brake controller.. and suggestions?
Old Nov 26, 2007 | 09:01 PM
Vinceg99's Avatar
Well as people have said over loaded is over loaded. I wouldnt risk it no matter what I would make. Now if you were going to be able to make good money at doing it I would step up to a larger trailer and then do it but then again even still that much weight on a SRW always makes me nervous I have seen a few people by me pulling trailers like mine (53' 3/4 car trailer) with a SRW so I mean obviously it can be done but the thing is how SAFE is it??!!
Back to the overloaded part if you have ANY kind of accident or get caught you could be facing some large fines and even worse if you are in an accident and cause a death theres manslaughter right there. There was an accident by me recently a Semi Trailer lost the whole wheel on the interstate rim and tire bounced over the median and smashed through the windshield of a car killing the man driving it guy says he didnt know it even happened for hours later, still not sure if him or the company will be held liable. He was a doctor and a feiend of mine worked with him. http://www.msnbc.msn.com/id/21825226/
Old Nov 26, 2007 | 09:12 PM
bnold's Avatar
14k trailer? No sweat...
Old Nov 26, 2007 | 09:35 PM
95turbo4wd's Avatar
well i just bought a Tekonsha Prodigy brake controller... ive read alot of good things about it so i hope it was worth the $$!! also im looking at buying the drawtite hide a goose hitch.. has anyone had experience with that hitch?
Old Nov 26, 2007 | 10:48 PM
rmk4x4's Avatar
Originally Posted by $oC@l CTD
I can't see a model number on that John Deere, but our 5525 WITHOUT loader and WITH cab weighs about 7400lbs...and I would guess that bailer to weight about 6-8k at the most...that load WITHOUT trailer probably doesn't weigh over 15-16K man...and I would say that trailer weighs between 6-8 max...so maybe TOTAL load is about 24k tops...not trying to argue, but there is NO way that tractor and bailer weighs 25k alone...
it is a 69 4wd 4020 with john deer factory cab with fluid filled rear tires and a new holland 650 net wrap i know the trailer is 7400 and my truck is 8140 i was judging the weight from my 580 case with a cab that i know is 15k and the tractor and bailer is alot more than the old case.
Old Nov 26, 2007 | 11:20 PM
Vinceg99's Avatar
OK dont know anything about weight of the tractor or such but saw that you said your truck weighed 8140lbs am I reading that right?? So the 2 gen SRW are heavier than 3rd gen duallies? My truck with me in it weighs 7640lbs and here I thought that was heavy
Old Nov 27, 2007 | 07:41 AM
bnold's Avatar
I believe it... My truck an SRW with toolbox loaded, full tank of fuel, and me in it weighs in at 7860... ranch hands add a good bit of weight.... as do tires and wheels I'm sure...
My 4240 with cab 4x4 weighs right around 11 or 12k I think... Trying to remember...
EDIT: according to Tractordata my 4240 dry with out MFWD is 9700 so I would guess 11k is about right.... It lists a 4020 as 8865lbs...
Old Nov 27, 2007 | 03:17 PM
rmk4x4's Avatar
that weight of my truck is with a custom front bumper fuel tank full and a goose neck hitch and a 5thwheel hitch and my slip tank with 100 gallons of fuel and a custom rear bumper. you know i never get more than 20k out of a set of tires. well i am going to do some bailing today with that setup got love the alaska hay weather.
edonald849
Feb 22, 2009 04:44 PM
drewallen42
Sep 27, 2007 09:51 PM
Trusty Steed
Feb 24, 2004 07:11 AM
rshelton88
Sep 10, 2003 09:55 AM
rkelso98
Jan 12, 2003 01:20 PM
