pulling 43000lbs 3500 miles
I think it is all in the driver. Sure, if I was going 65-70 mph, I think I would have been a risk to all. The max speed I ever saw was 50mph. Most of the time I was slowing down for bumps or curves or going up or down hills. On the flats I did go 50mph though. I was passed by every car there was. It is all the driver. The axle according to the dana website was rated for almost 5k more. The tires (g-rated) were rated for the load. The tires on the trailer were just overloaded by about 200 lbs. Everything else was built to spec. Plus airbags and good shocks helped out immensely.
The only hill I had to drop to second was around summit lake canada. That 8% grade was about 10 miles long or so. I did stop 90% through the pull because the temp on the motor was right at the top of the normal line. Let her cool down till the fan kicked off and away I went.
Originally Posted by Toto
I think a short jail term is in order.....flame away!
Originally Posted by ridofpwrstroke
Say what you want, that shop was worth every penny and I would do it again.-------I hope I dont have to though.
Pulling 43k lbs.
Originally Posted by P.J
He said 12K axles, as in 24,000 lbs. total, ....right???
G-rated is 3750 for the truck rear= 7500lbs rear end of truck, 235/80/16 trailer tires were rated for 3500 lbs tire. 28000 lbs was what I was rated for on tires alone for trailer. I weighed in at 30,5 I think, which would put me 250lbs over weight each tire. I drove at night because temps during the day was in the 90's. A truck driver in Nebraska saw my weight at the steel place. He said he would run it and gave me advice. He said the dexter axles may only be 12k axles, but he wouldnt worry bout them, they are hugely underrated. He was right. He told me about the road heat and that the tires would have probs during the day. Said he would run at night. I did and had no tire leaks. Other than that, he said the way I was set up with the bigger brakes, jake brake, and heavy duty tires to run it. Should not be a problem. He was right about that as well.
Originally Posted by kens_isb
Good to see an Iraqi Vet pull it off
where were you at? I was there during OIF3 at FOB Warrior
Good to have you back. I was there during OIF2 at Butler Range, Mamudiyah, Lutisfiyah, Camp Liberty, and Camp Dogwood. On the road alot. Good feeling to be back huh? I have been back for 10 months and they have flown by. I was with 1st Cav. You?
yea i've been back since november and i was with the 42nd ID (national guard div.)
Originally Posted by BEERGUT
Wow -- that picture of the loaded trailer reminded me of "The Grinch" with his sleigh loaded up!
