prodigy brake controller wiring for a 95
Old Jun 6, 2005 | 10:29 PM
hotmopr's Avatar
I have a 95 and I also have a prodigy on the way. I read somewhere that 95s didnt come prewired for a controller. Is this true even though I have a reciever and trailer wiring which I think is factory? I also have 3 plugs mounted to the bottom of the dash. Could one of these be the baby? All are black one has two pins and it is below the fuse box, out of the other two one has 6 pins and one has 2 pins both are to the right of the column. If these are not the plug, Where can I find a wiring diagram or someones brain to pick???
Old Jun 7, 2005 | 09:42 AM
JEMGTX's Avatar
The 95's w/the trailer tow package did not have the "plug". When I installed my Prodigy in my 95, I did locate the "brake" wire, which is there. I just don't remember what side of the fire wall I found it on. You will have to hard wire
the power & ground, it is not a "plug & go" with the 95. It is a easy project, and
good directions with the controller.
Good luck.
Jim
Old Jun 7, 2005 | 09:09 PM
hotmopr's Avatar
I finally found that darn wire. It was partially taped in the loom. All I saw was the little tag. It was on top of the 84 pin connector under the dash. Thanks
kayjh
Jun 27, 2006 12:11 PM
tdupuis
Oct 1, 2004 10:49 PM
Synchiropus
Oct 8, 2003 11:33 PM
hotdram
Jun 25, 2003 08:36 PM
Buzz
Jan 24, 2003 11:21 AM
