over under axle conversion.
Old Apr 9, 2011 | 04:58 PM
critser660's Avatar
I bought a new to me 1992 Prowler and it is too low to comfortably pull with my truck in sig. After looking around on the interweb, I think an "axle flip" is the answer, but the Dexter kits don't come with a tie plate having holes for shock mounting. After writing them, they responded with use the old tie plates. My questions are- will the extra hieght put more stress on the shocks at the tie plate? Would the trailer ride terrible without shocks? Most trailers don't have them anyways? Just trying to get some opinions since I haven't made up my mind. I'm thinking of reuseing the tie plates, mount the shocks to plates and reweld the top mounts at about the original angle they started out. Any idea's?
Old Apr 9, 2011 | 07:55 PM
6.7 4ever's Avatar
i'm considering the same option and have read somewhere that with the Dexter kit you can keep the original plate on top of the springs keeping the original shock length.
The original plates would be on top with the new kit below the springs.
Old Apr 10, 2011 | 03:12 AM
CrazyCooter's Avatar
I usually use the old plates and relocate the upper mounts. This is usually the easiest way.
You could leave the shocks off, but if you decide to run them, the ride in the cab as well as the trailer will be better and may save breaking the springs if you drive on bumpy roads.
Old Apr 10, 2011 | 03:02 PM
Derek Timm's Avatar
Just to be sure you do know that "Flip" the axle is not what you do. These axles are cambered and if actually flipped over would destroy tires and result in poor handling.
The kits are OK but you can get new spring mounts for about $15 and with some prep and careful measurement weld new mounts to the top of the axle and save some money. If you really want the shocks you'le probably have to fabricate the new mounts. Using the old mount if the distance changes as much as the height chages would most likely destroy the shocks.
Old Apr 10, 2011 | 09:19 PM
critser660's Avatar
Yeah, I know it's not a flip of the axles. That's why I referenced the Dexter kit. I have decided to do the spring over and relocate the top mount of the shocks at about the same angle as before. Also, lower the bumpstops just incase that is brought up. Should work out and gain me the clearance I need to not rip the bedsides off the truck. The wife already thinks I spend too much on the mistress. Thanks all.
Old Apr 10, 2011 | 10:42 PM
Derek Timm's Avatar
Yea even at stock height the Dodge 4x4 is too tall for a lot for 5th wheel trailers. A good 6" clearance or more is good insurance against damaging the truck or the trailer
ElkyRacer
Oct 10, 2008 04:25 AM
Idaho Guy
Feb 20, 2005 12:54 AM
bigfoot
Aug 14, 2004 02:22 PM
Dodgezilla
Feb 13, 2004 03:40 PM
hotdram
13
Mar 10, 2003 02:43 PM
