TT: Leaf springs over axle conversion?
Old Feb 16, 2005 | 09:10 AM
Idaho Guy's Avatar
We have a 19' Nash TT and I'm looking to get a few more inches of ground clearance to avoid underside damage going into some of our favorite camping spots. I've seen numerous TT's with leaf springs OVER the axles. Has anyone done this? Any special tools or equipment needed? If it's a simple enough job, I'd like to do this myself and avoid the $200-$300 or whatever to have it done. Thanks.
Old Feb 16, 2005 | 11:28 AM
Mechanos's Avatar
New spring perches (2 per axle), new u-bolts (not absolutley required but recommended), and a welder to weld the new perches on the axle tubes 180° from existing perches. I did this to my last trailer to level it out.
Old Feb 16, 2005 | 05:06 PM
Casey Balvert's Avatar
If they are Dexter axles, Dexter sells a kit that for mounting the springs over the axles. I don't think they are that expensive. You can find it at http://dexteraxle.com/over_under_conversion_kits and you can find the instructions at http://i.b5z.net/i/u/1080235/f/059_551_00.pdf
Old Feb 16, 2005 | 05:32 PM
Idaho Guy's Avatar
Thanks!
Great info, guys. Thanks!
Old Feb 16, 2005 | 05:52 PM
Haulin_in_Dixie's Avatar
If the bolt pattern on the backing plates is square or six hole, just turn the axles over. I have done this on construction trailers a couple of times (bent axles)
Old Feb 16, 2005 | 09:01 PM
flyingd's Avatar
I did just what Mechanos did and it worked out great. I don't have to worry about scraping the back end anymore, or scraping the waste valves off. Do it.
Old Feb 16, 2005 | 10:40 PM
Mechanos's Avatar
HID... just turning the axles over inverts the camber on the axles. Instead of positive camber, they'll have negative camber and cause the tires to wear badly.
Old Feb 16, 2005 | 11:35 PM
I wouldn't think that a straight trailer axle would have camber, or toe, and of course caster is irrevelent with no steering. Those that do have the axle actually bent in the center. And they wear tires very badly.
Old Feb 17, 2005 | 09:00 AM
Smokeman's Avatar
Every travel trailer I've ever worked on has the axles prebent. Flipping them is not an option. I moved my springs to the top of the axles as described above. Four spring perches was all that was required as the ubolts all came apart fine. It takes about 3 hours to do the job on a tandem axle trailer.
Old Feb 17, 2005 | 12:46 PM
ozman3918's Avatar
I did the perch weld on my last trailer and was a great improvement to clearance and no loss of stability while towing.You can do it yourself with a welder and a few hours.I had a friend do mine.
Old Feb 17, 2005 | 03:44 PM
Diesel Dave's Avatar
I did it on my 5th wheel also with no problems with handling, etc. However, I had to build a portable step to carry in the 5th wheel since the first step is now too high off the ground.
Old Feb 17, 2005 | 06:50 PM
bluepp's Avatar
Just one thing here guys . Most all trailers have the brake wireing running through the axles. Welding with the wireing in there could melt the wireing.
Remove the wires and reroute them on the outside of axles at the rear side . These wires just dangle around inside the axles and I have seen them wear threw the insulation and then short out and no trailer brakes. Have seen cases where many hr. spent trying to fix brakes before the bum wireing was found.
Old Feb 19, 2005 | 10:54 PM
HURA1's Avatar
i know this one too well. the previous owner of my 5er flipped the axles without new mounts. there was a - camber and sure enough the extra pressure wore out the bearing nut washer that holds everything together. as i was getting off the freeway to get gas, i looked to my left at my tire along with the whole brake drum flying down the slow lane doin about 65mph this was thanx giving day in the middle of indio with not a **** thing open. MOUNT THE NEW BRACKETS 180* to keep the axles right. BTW the tire didnt hit anyone but found it about 50yards off the freeway and about 1.5 miles down.
Old Feb 19, 2005 | 11:03 PM
HURA1's Avatar
Old Feb 20, 2005 | 12:54 AM
Whatever camber or the lack of it may affect, I will not affect the bearings. You lost a bearing, had nothing to do with camber.
PeytonMaterne
Aug 27, 2012 08:33 PM
97catintenn
May 28, 2010 08:29 PM
95turbo4wd
Dec 12, 2007 05:59 PM
Joe T
16
Jun 12, 2007 12:11 AM
bigfoot
Aug 14, 2004 02:22 PM
