Need some help with RV fuse panel
Old Jul 24, 2009 | 08:26 PM
stickk's Avatar
I just noticed that the 2-30 amp fuses on the top of the pnl were blown. I replaced them and flipped the battery switch on and they blew again. What is going on? Thanks.
Old Jul 24, 2009 | 08:34 PM
rich's Avatar
sounds like a short somewhere
Old Jul 24, 2009 | 08:58 PM
Jeff in TD's Avatar
What do those fuses go to?
stickk's Avatar
Converter fuses
Old Jul 24, 2009 | 09:10 PM
rich's Avatar
could the converter gone bad or shorted out
Old Jul 24, 2009 | 10:03 PM
stickk's Avatar
Maybe. I have very little elec knowledge. I wouldn'tr even know where to start.
Old Jul 24, 2009 | 10:21 PM
67HotRod's Avatar
The top two should be the main feed for the converter. Sounds like the converter is having a problem. Depending on how old it is, might be a simple card replacement. Write down your converter info and contact a RV parts/repair center.
Old Jul 25, 2009 | 02:28 AM
RVPro's Avatar
I am a Rv tech and the two fuses in question are for the output of the converter to the battery. You need to check 3 things. 1st check for proper connection at the battery + and - . Second a short on the positive wire to the battery. Finally check your battery does it have water? Does it look pregnant (swolen). Hope this helps.
Old Jul 25, 2009 | 06:13 AM
huntr70's Avatar
I was going to suggest the + and - hookup as well......
Ranger12
Aug 30, 2012 10:29 PM
Exekiel69
Dec 30, 2011 07:46 PM
bigjohn92
Nov 25, 2010 01:32 PM
Crossy's son
Jul 22, 2009 09:14 PM
Evildiesel
Nov 18, 2005 04:12 PM
