Can't get my cap off!!
Old Mar 20, 2009 | 09:39 AM
Dodgezilla's Avatar
Any tips on getting a cap off of a truck? Apparently mine has been on this truck for 5 years and I can't get it to budge. Of course I pulled the clamps off and checked for any bolts or screws that may have been holding it on but there is nothing but the weatherstripping between it and the bed rails. I sure hope someone was not stupid enough to use double sided tape when they installed it.....
Old Mar 20, 2009 | 10:07 AM
SundayMoney's Avatar
My last truck had a cap. In the summer the rubber gasket between the bed rails and cap would get hot and stick like super glue. I'd lay in the bed of the truck,put my feet on the roof of the cap and push.
Popped it loose every time.
Old Mar 20, 2009 | 10:19 AM
rich's Avatar
nickel says they used double sided tape to get a good seal
Old Mar 20, 2009 | 10:46 AM
Dodgezilla's Avatar
SundayMoney, I can't do that because mine is a high-topper. My legs are not that long.....
Old Mar 20, 2009 | 10:55 AM
TexMexCowboy's Avatar
Dude have fun. lol If i was near you I would help just because it sounds like it is going to be fun getting that thing off. lol
Old Mar 20, 2009 | 11:12 AM
Dodgezilla's Avatar
I have a feeling I'm gonna have to cut it off with the Sawzall!!!!!!
Old Mar 20, 2009 | 11:31 AM
Its cab high in the front isn't it? Start there.
Old Mar 20, 2009 | 11:57 AM
rattlerbob5.9's Avatar
Use the jack method along with ample amount of wood to spread out the load and don't get in a big rush !!!!!
Steady pressure along with some heat will do it start in a rear corner and work your way around and stick a thin shim under it when you get some space so it does not reattach itself while you progress along.
Old Mar 20, 2009 | 12:00 PM
Dodgezilla's Avatar
Yes Sir it is. I was planning on bringing the hairdryer out too just like st.rodder2 suggested. I'll report back sometime this weekend when I get a chance to mess with it more. I was trying to do this before I opened up for business this morning and now I will have to wait until tomorrow....
Thanks for the suggestions..
Old Mar 20, 2009 | 03:49 PM
12valve@heart's Avatar
Just hit the highway without putting the clamps back on. It'll disappear in no time.
Old Mar 20, 2009 | 04:18 PM
ramlovingvet's Avatar
DTR'S Chaplain
Gee your a big help LOL
Old Mar 20, 2009 | 05:54 PM
tool's Avatar
What about gently cutting under the edge of the cap with a cutting torch?
I don't think anybody would notice if the box was an inch lower.
haha
Hair dryer might be the best bet, or try spraying the edges of the gasket with WD40 and see if that helps overnight.
Old Mar 20, 2009 | 06:20 PM
Utundra's Avatar
Would some heavy monofiliment line work to "saw" through it?
Old Mar 20, 2009 | 07:21 PM
Valv's Avatar
Skidsteer loader will do it fast !!! Use the pallet fork attachment.
