MaxBrake Controller
Old Dec 30, 2011 | 06:23 PM
Busboy's Avatar
I haven't read up on this brake controller but if I get the drift here that the direct link one uses the signal from the ABS, I can't see how it could become anti skid on the trailer as there are no wheel speed sensors. Surely they wouldn't release the trailer brakes in conjunction with the trucks brakes. Did I also get the the OBD2 connector is constantly used by the brake controller? If so what about using a programmer? Or was that just to upload the brake controller.
Old Dec 31, 2011 | 11:04 AM
Rednax's Avatar
My "understanding" is that it reads from the OBD port continuously.
Old Dec 31, 2011 | 11:16 AM
carl48's Avatar
delmar i got maxbrake and smartbrake mixed up. to early that morning. that is the maxbrake you want. rednax the direct link seems so well thought out there has to be some way they are sensing pressure. i think next week i will call the company and ask
Old Dec 31, 2011 | 11:19 AM
Rednax's Avatar
Carl48, have them send you the Towing Guide. I know a lot of us know a lot about towing, but it's a handy reference, good to show to others, and get's a man on the mailing list.
Old Jan 28, 2012 | 07:44 AM
unit74's Avatar
Originally Posted by Rock Hauler
Just installed my Direct Link controller in, very simple to install, 1) connect to brake controller connecter
2) connect to OBDII connecter
3) plug in the hand held remote.
Then all I had to do is start the truck up and press the brake and release,then it started configuring for my truck. The nice thing about it is the hand held remote,mounted it next to the radio, looks like a CB mic and if I want all I have to do is pick up the remote to change any settings. Haven't had a chance to tow anything with it yet but I will let you know.
Problem I see with it is that it requires the OBD II port. For us running tuners or monitors such as the Edge, we have to choose between the two. For this reason, the max brake appears to be a better route for those folks who do not want to drop their monitors/tuners.
Old Jan 29, 2012 | 09:57 AM
carl48's Avatar
i called direct link. and they explained how it worked. it uses speed data and changes % braking based on some formulas. in other words, just another piece of junk. the max brake is the only good controller on the market. smartbrake scraped plans for coming back out with a new one
Old Apr 22, 2012 | 07:31 AM
hamilton71801's Avatar
Hey Hauler, how bout an update on that controller.
Old Apr 24, 2012 | 05:51 PM
Rednax's Avatar
Here's a link from the big AIRSTREAM board with a few who have used the DIRECLINK.
http://www.airforums.com/forums/f439...ler-86877.html
Old May 2, 2012 | 01:42 PM
junebug95628's Avatar
The OBDii port is just a serial connection with a proprietary OBDii connector. You'll see at the brake controller a DB9 connector. Just use a DB9 splitter to split the tow vehicles signal between two devices. Serial protocol doesn't care that there are two connections.
Old May 2, 2012 | 01:50 PM
Or use this
http://www.webpg.net/sc/details.asp?item=obd2y
jrs_dodge_diesel
Jun 28, 2013 07:00 AM
klx650a2
Jun 6, 2008 07:45 PM
1966Hemi
Apr 14, 2008 08:00 PM
wallawalla
16
Mar 1, 2008 10:28 AM
finnswede
0
Feb 11, 2008 11:37 AM
