Load range G tire option for 16"'ers
Old Jul 29, 2005 | 01:27 PM
Patrick Campbell's Avatar
Originally posted by ridofpwrstroke
If you need traction off road, dont get the goodyear g rated tires. I ran them on the back of my truck which weighed in at 7450 with gooseck, ran 80psi for 3500 miles with that weight on stock rims and never had a problem. I only use them for heavy hauling. They are definately built right tires. Expensive though. 200 a pop. THese tires never gave me a problem pulling the shop up from nebraska through canada into alaska at 43k gross. Definately worked for what I needed it to do.
Are you saying the rear end weighed 7450# and you only ran 80 PSI? Or the entire truck....
Did you check out the other G's with some tread on them, posted in the other "LOAD RANGE G TIRES" post?
Old Jul 29, 2005 | 01:35 PM
ridofpwrstroke's Avatar
That weight was only the rear two tires. My rims were only rated for 80 and I didnt want to go any higher. They worked fine with just 80 psi with that weight. Didnt even know the weight was on it.
Old Jul 29, 2005 | 02:55 PM
does it say on the wheels somewhere their max pressure rating?
Old Jul 29, 2005 | 02:57 PM
mine said 80 psi max. Inside of the rim.
Old Jul 29, 2005 | 03:01 PM
interesting - which wheels are those? the Forged 16" alloys?
http://dodgeram.info/2001/color.html
Old Jul 29, 2005 | 03:31 PM
I bought some winter rims that were steel. Said it on the rim. I know the dually rims have it on it as well.
01RAMer
19
Sep 28, 2011 11:25 AM
Roperteacher
Jul 30, 2008 07:24 AM
Firstgenfanatic
Apr 10, 2008 12:24 PM
Mark Hodowanec
Mar 19, 2007 05:55 PM
