lifted 5th wheel/goose neck
Old Feb 26, 2007 | 11:43 AM
goodeyesniper75's Avatar
does anyone tow a 5th wheel or goose neck trailer with a lifted truck? i have the 6" kit on my truck and want to tow a 5th wheel, do i need a spacial trailer?
Old Feb 26, 2007 | 11:59 AM
DodgerDoob's Avatar
I have a four inch lift on mine. This topic has been covered before on here if you want to do a search. The main issue is the clearence of the neck over your tailgate. If the trailer has an adjustable hitch i.e. pipe inside pipe with bolts hoding it together, usually you will be fine. My horse trailer is at a little slope, so I will probably put bigger tires on it when I get new trailer tires. I can't lower the truck so II'll lift the trailer.
Old Feb 26, 2007 | 12:03 PM
JD Dearden's Avatar
I am a 4" lift and my tires and rims lifted the truck 2 more inches, my trailer is lifted a little and rifes slightly angled but I still have 8" of clearance.
Old Feb 26, 2007 | 01:27 PM
i was thinking that if i put like a 2" block on the trailer with slightly bigger tires...also i dont want a horse or camper type trailer i want a flat bed one so i could probably find one with a higher hitch point.....
Old Feb 26, 2007 | 03:32 PM
DodgerDoob's Avatar
All the flats I pulled had pretty good clearance and a lot more adjustment on the neck than I needed.
Old Feb 26, 2007 | 09:18 PM
what brand trailer are you using?
Old Feb 27, 2007 | 03:48 PM
DodgerDoob's Avatar
I don't think I've ever pulled any national brands like Gator or Big Tex. Most trailers have the same design, just maybe different materials. I forgot that I also added bigger tires and they added maybe another inch to my height.
guzzirider
Dec 9, 2007 08:13 PM
Vinceg99
Feb 8, 2007 02:45 PM
KATOOM
Feb 2, 2004 01:56 PM
kamper
Mar 29, 2003 10:13 PM
USMC64-70
Dec 22, 2002 08:07 PM
