important gauges
Old Jan 31, 2010 | 04:14 PM
gwayne919's Avatar
important gauges
Please tell me which gauges are the most important to install in my 1 ton diesel & why?I am referring to additional aftermarket gauges that will help me save trouble later & help to solve running problems.
Old Jan 31, 2010 | 04:17 PM
Greed 93's Avatar
What year is your truck
Old Jan 31, 2010 | 04:23 PM
G1625S's Avatar
Welcome to DTR Go to the upper left of this page and click on usercp and fill out your signature so we know what your rig is. It's hard to say what gauges you need without knowing what you're driving
greg
Old Jan 31, 2010 | 04:29 PM
Pirate's Avatar
The most important gauge in any truck is the under seat gas detector. Lets you know who ripped it and how deadly the fumes are.
Old Jan 31, 2010 | 04:43 PM
gwayne919's Avatar
Sorry guys, thought I had filled out my signature. Let us try again. Oh, BTW, my nose is still my best gas detector.
Old Jan 31, 2010 | 04:45 PM
gwayne919's Avatar
It sure is cold out here
Trying again as a diesel.
Old Jan 31, 2010 | 05:14 PM
annabelle's Avatar
EGT's ,fuel pressure, boost, and tranny temp.
Old Jan 31, 2010 | 06:49 PM
AH64ID's Avatar
For a stock truck I would say, fuel, trans, EGT, boost in that order.
Old Jan 31, 2010 | 06:59 PM
CODODGE2500MAN's Avatar
Fuel, Fuel, Fuel.... Did I mention fuel? Take it from some one that DIDN'T do it this way and paid for it!
If you're Fuel pressure drops, you won't be moving, so your egt (exhaust gas temp) won't be an issue, nor will you be creating boost....
If you're towing and stock I'd get Fuel pressure, Trans, then egt and then boost. The order after fuel isn't really going to matter as you'll probably end up getting those 3 in a package (boost, egt, and trans temp) with an a-pillar pod to hold them. You can do 3 on the a-pillar and one on the steering column or have someone make it so you can do all 4 on the a-pillar w/ fiberglass...
Welcome!
Old Jan 31, 2010 | 07:28 PM
annabelle's Avatar
How much do you tow? If you tow a lot I'd go EGT, fuel, tranny and boost. If you don't tow I'd say fuel , tranny, EGT, and boost.
Old Jan 31, 2010 | 08:03 PM
gwayne919's Avatar
Smile Thanx
So, Fuel pressure,EGT(ex.gas temp) & boost, since I am not running an automatic tranny is what I need. Should these be mechanical or available with sending units & which is best for the buck.
Old Jan 31, 2010 | 08:05 PM
gwayne919's Avatar
I only tow when I am on vacation otherwise I only drive fast.
Old Jan 31, 2010 | 08:13 PM
AH64ID's Avatar
I would go with electrical. They are a few more $$, but I like the simplicty of them.
That is a good setup for towing or playing!
Kman9090
29
Dec 6, 2007 06:43 PM
rip 112
May 8, 2007 02:22 PM
coontz0473
17
Sep 22, 2006 03:52 PM
Duckman1993
Sep 12, 2006 07:50 PM
admin
17
May 3, 2003 11:45 PM
