Goose trailer parking
Does anyone use an extension on their goose neck trailers to extend down from the coupler to a 2 5/16 inch ball for parking in very tight places using a front hitch? If so how well does it work, or is there another solution? I thought about welding a 2 inch receiver on the front to take a draw bar but the draw bar would have to be too long and would not be able to support the weight. Any comments?
Maybe I'm missing the concept, but you want to put a bar in your hitch, have a 90* bend up, and have your GN attach to that? How are you going to support it from bending/breaking/flexing in 360* of motion?
My trailer would have to much pin weight to try that with the axles are further back. I did see a ford on I95 towing a gooseneck with a ball mount in the rear hitch The truck was a jacked up dually 4x4 and still needed a hitch to elevate the front of the trailer.
That's simliar to what I do when necessary. Our GN is parked in an open area, so it usually isn't a problem. However when I do need to get it in a tight place, I just take the bucket on our Kubota, pick up the front and get er' in there.
I love the idea of the fork lift but I don't have one and it would need to be a 4X4. Colo_River_Ram it looks like you using an extension with the fork lift, that's like what I meant, extend straight down and hooked to a 2 5/16 ball front hitch on a Landrover so it would have to come down a little further. I would only use it for parking the empty trailer when not in use, it's up hill at a funny angle and needs to be within a couple of inches of a fence and my 5ver so you really need to see exactly where the trailer is. I currently have a tag along equipment trailer that I use and park there, the goose would replace that.
Any other suggestions for tight goose trailer parking?
I have a hole in the end of each fork I can put whatever size of ball in that I need..I then raise the forks to what ever is needed to hook up to the trailer (Tag or GN). Your idea will work if it does not overload anything, as you are just spotting the trailer with it and not going down the highway at 75.. Here's a thought for backing and keeping it square measure the width of the trailer being towed and then measure the same distance and place a piece of tape on each mirror (I'm assuming you have tow mirrors)..then you can sight down the side rails of the trailer and compare it to the lines on the mirror.. the Dodge mirrors are flat which helps as backing with the "Cheby" mirrors suck..practice makes a good trailer backer..Hope this helps..
but I have to back in at 90 deg over the curb from a main road then up hill with the drivers mirror folded in just a couple of inches from the fence and the 34 foot 5ver about a foot from the overhang of the house, through a gate and then jack knife the 5ver towards the fence at the front until I have about a foot clearance. I've been doing this for about the last 15 years, that's not the problem, the problem is the equipment trailer that I use all year round when there's a foot or so of snow on the hill and the trailer won't go exactly where you point it. It also has to be backed under the 5ver so the back of the trailer almost touches the 5ver front legs and is just a couple of inches from the fence. Don't forget it's at an angle and you can't see squat with the mirrors. Hooking to the front makes the exercise a breeze.
especially in the dark the headlights work well.
Mine has mirrors also
It seems like you could use a front receiver with a goose if you can come up with something to take most of the pin weight. How about a something kind of like those rear 'helper' deals with wheels that they sell for receiver hitches? Maybe a 'crazy' (caster) wheel with a stout coil spring so that the wheel would follow the ground ..... ???? My 2¢
