Which cleaner?
Which cleaner?
I put this here cause I figured that I would get the most responses here...If its the wrong place, my apologies.
I have an aluminum-sided travel trailer(2005) that is starting to show some wear. My question to you all is this. What cleaner have you guys used that gets the aluminum clean, without stripping the surface? I have some black streaks that do not come off and black streak remover doesnt work that well. I have heard to use simple green, but I also heard that it strips the surface and makes it dull.
Again, what have you guys used with success?
I use Simple Green it works better then any black streak remover I've ever used and its cheaper. I use it straight and do small areas and rinse before it can dry on the trailer.Its almost effortless.
Bradleysram
19
May 12, 2009 08:36 AM
Ruralmedic
26
Oct 20, 2006 10:36 AM
