Brake Controller
Old Jul 30, 2004 | 03:34 PM
Buzzer's Avatar
Brake Controller
Looking for the brake controller connector on my 2004.5. There isn't a blue connector or any other spare connector where the instructions for the brakesmart controller says there is one under the dash. Anyone know where it is???
Old Jul 30, 2004 | 06:52 PM
NJMurvin's Avatar
Do you have the trailer pre-wiring option? If so, it's there. I had a heck of time finding mine as well. It was tucked way up under the dash above the ebrake pedal. It was tied to another glob of wires and connector with a break-away tie wrap. I just pulled firmly and the tie wrap broke free making it easier to get to the blue plug. I have the Tekonsha Prodigy and the Dodge-specific connector so the whole thing was plug and play - except drilling the dash for the mounting bracket.
Good luck,
Neil
Old Jul 30, 2004 | 08:09 PM
Bigredmachine's Avatar
Go inside the drivers door, head at floor level. Look up along the left side above the parking brake pedal and there is a wiring harness connection with a bolt in the middle. The blue connector is sitting right on top of it. Some say the had to cut the wire wrap it's held on by, others have had to take the bolt that holds the harness connector together and remove the wire block. I was able to connect mine as it sat.
Of course as neil says, if you don't have the trailer towing package it might not be there In that case I cant help you, good luck.
Old Jul 30, 2004 | 09:46 PM
Buzzer's Avatar
Thanks for the info. I do have the trailer towing option and I looked pretty much every where but will take another look around based on your inputs. Thanks Guys. I really appreciate the help.
Old Aug 2, 2004 | 04:12 PM
300 SDL's Avatar
You will love the BrakeSmart.
Old Aug 2, 2004 | 05:22 PM
Buzzer's Avatar
Thanks. I hope so. Ordered it yesterday!
Old Aug 2, 2004 | 07:13 PM
JohnnyH's Avatar
Yeah buzzer you will love it. I installed mine about a week ago and towed my fifth wheel from ohio back to long island. Very smooth. Let us know what you think. I was able to connect my brakesmart without removing the blue plug, just a little tight is all.
Old Aug 2, 2004 | 07:26 PM
natstayl's Avatar
Did you find it? It's right where BigRedMachine says
Old Aug 3, 2004 | 07:41 AM
Buzzer's Avatar
Yes I did find it finally. It was tucked in back of the firewall insulation. Very hard to find. After poking around under the dash for about 20 minutes I saw a little blue plastic protruding from the insulation. Then it was a chore to pry it loose but it was there.
Old Aug 3, 2004 | 10:38 AM
Jonesey's Avatar
All of the trucks are wired identically and for the tow package. If you orderd the tow package you also get the pig tail that connects the controller to the connector under the dash above the e-brake pedal and you also get the seven pin connector on the rear bumper.
Old Aug 3, 2004 | 06:13 PM
Casey Balvert's Avatar
Except that without the tow package you don't have a brake wire running to the rear and no 7 pin plug back there.
Old Aug 15, 2004 | 11:09 AM
deviousracing's Avatar
any one have pics of where they mounted their controller
Old Aug 15, 2004 | 05:54 PM
natstayl's Avatar
I moved mine to the bottom storage bin between the seats. I adjust it before I move the trailer and haven't had to touch it while in motion.
Nat
Busboy
21
Jun 10, 2011 11:39 AM
kingofdodge7131
Jan 31, 2010 10:15 AM
DuaneWKKC
May 9, 2003 11:08 PM
atc250r
Mar 22, 2003 12:27 PM
PADZZ
Mar 18, 2003 09:47 AM
