Any tricks for winterizing
Old Oct 7, 2003 | 10:03 PM
Soon2BDiesel's Avatar
Some people say blow the lines clear of water.Some say use antifreeze. Also been told antifreeze makes your water taste like crap.Does anyone recommend a brand or any tips. Temps as low as -10f. ??? ???
Thanks
John
Old Oct 7, 2003 | 10:06 PM
DF5152's Avatar
Re:Any tricks for winterizing
if u use the anti freeze make sure u clean the system good before u use it again if u can taste it you didnt cleen it good enough
Old Oct 7, 2003 | 10:18 PM
js's Avatar
js
use rv antifreeze and flush very well in spring and you will be ok
Old Oct 8, 2003 | 12:40 AM
SuperGewl's Avatar
I blow my trailer dry including the water heater. Just make sure you don't use high pressure because you can burst a water line. I set the compressor to about 20psi and use the shore water input to blow the system. If you live in an extremly cold climate you may want to put some rv antifreeze in the water traps and some in the santanks also.
Old Oct 8, 2003 | 01:16 AM
RobG's Avatar
I used to use antifreeze, but since I use my camper throughout the winter, this got to be costly. I don't drink from the camper's water supply, though, which helps.
Instead, I drain the hot water and fresh tanks, then use the blow valve to blow the water out. I use no more than 40 psi since the water pump is designed to pump at 45 psi.
Rob
Old Oct 8, 2003 | 08:53 AM
MnTom's Avatar
The way I winterize mine is to blow the water lines out with 30 psi air pressure (don't forget the water heater), put the water heater in by-pass, go to the pump and hook up a line to go onto the suction side of the pump and let it pull anti freeze out of a jug. Make sure that you have pink coming out of all faucets and don't forget the shower head (if you have one). That way I only need a galon to do the whole job. BTW I also pull the anode rod on the water heater too. It only takes me about 20 min from start to finish.
Tom
Old Oct 11, 2003 | 11:44 PM
greatwhite's Avatar
Make sure ALL tanks are drained. And RV Antifreeze only. It won't kill you.
Then I do just what MnTom does. Haven't frozen any lines in 10 winters
Old Oct 13, 2003 | 08:28 PM
gadgets's Avatar
I do exactly what SuperGewl says; works like a charm, & I don't go thru a whole lot of antifreeze, just enough to protect the traps.
I made up a quick-connect; one side fits the Schrader air line & the other has a 3/4" hose thread with a water-hose quick-connect.
Works Great!
Rene
Old Oct 14, 2003 | 12:52 PM
PHONSE's Avatar
Don't forget the outside shower if you have one and also very important the toliet must have anti-freeze run through the lines, make sure the color pink comes out into the bowl.Before running anti-freeze through the lines drain water heater and then close BY-PASS valve to water heater otherwise you will fill the water heater with anti-freeze.
scsulfri
14
Oct 31, 2005 08:53 PM
djcheez
Oct 25, 2005 06:52 PM
Sweeper54
Oct 10, 2004 10:18 PM
cft68
Nov 30, 2002 07:06 AM
TEDHRS
Nov 16, 2002 02:40 PM
