Air/exhaust mods complete can I tow at a higher Juice setting?
Question for all you experts. I have a toy hauler that I use to tow three motorcycles to races. I was running the Juice w/attitude at level 2 towing about 8,000lbs on my 2005 Dodge Ram 2500 Diesel truck. My question is I have just added a AFE Stage 2 air intake system and a MBRP 4" exhaust can I run the Juice at a higher level? Playing around I see that towing an 8000lb load I get much better fuel milage running at higher settings. I just want to make sure that as long as my EGT's are low enough can I bump up the setting?
Thanks
Thanks
I know Edge recomends you don't tow at the higher settings, but I have tinkered and towed a little bit in level 3. What I noticed was it is easy to get the EGT's up above where they normally run in level 2. However I haven't tried it on any of the bigger & longer hills I tow on because I was afraid of transmission damage. Now that I've torn the trans up and am getting the DTT I might just have to continue my research.
I guess my question is if my EGT's are under control is there anything else I should be worried about? I'm most concerned about the transmission, will running on a higher setting potentially mess with the transmission or anything else? Or as long as my egt's are good is that the only thing I really need to watch?
Thank you
Z
Thank you
Z
I haven't done any mods to mine for that very reason. After reading & posting several threads, I have come to the conclusion that if you don't want to do any preventative upgrades to the tranny, that you will have problems if you are not very careful.
DWK
11-17-2007 07:20 PM
streetsmoker
08-09-2006 05:55 PM
joe22790
05-13-2006 12:10 PM
