7 pin connector location
I was wondering how many people have added an additional 7 pin connector in the bed of their truck for 5'er towing?<br><br>Also, how many are using the stock 7 pin location under the bumper? How did you make the camper wiring longer and how do you keep it off of the tailgate?<br><br>Tim
Re:7 pin connector location
Tim,<br> The 7 pin on my truck is moved to the bed, just behind the wheel wells. If I had it to do again, I would go in front of the wheel well for easier access.<br><br> I made up a jumper for my boat trailer to run from the bed under the tailgate and have eliminated the rear plug entirely.<br><br>Bill
I bought my 96 used and it already had the in-bed 7 pin as well as the bumper location. My gooseneck wiring is setup for the bumper so I use the in-bed to connect the revolving beacon that I sometimes run.<br><br>The bumper location also allows me to plug in all of the different tag-along trailers I pull occasionally.
Right now I plug my 5th wheel into the factory harness, but I did order a 7-pin connector to install in the bed.
Looks like it should be a pretty clean and easy install.
Tony
EDIT: Ordered from http://www.etrailer.com
Tony
I took the factory plug out of the bumper and replaced it with a 7 pin with a 4 pin next to it. (maybe a hoppy brand?) That way I don’t have to get under the bumper to reach the 4 pin when I need it. The Hoppy came with a 4 pin connector that I plugged into the factory 4 pin connector on the truck. I then cut off the factory plug and used that wire to hook up the plug mounted in the bed. The only wires that had to be split were the brake signal, backup and power lead. Everything else got it’s own individual wire. Took about 45 minutes to do. The hoppy plug even lined up to use the existing bolt holes in the bumper.<br><br> <br> http://www.trailerwiring.com<br><br>Part # 47185<br> <br><br>
What I found funny is one of there warehouses is about 15 minutes from my house, yet they shipped my item from St. Louis... :
I still got it in a couple days... just haven't installed it yet... ;D
I decided to buy a 7' extension and just run the cable over the tailgate and down to the factory plug. I am going to cover the cable with water pipe foam insulation to make sure it doesn't rub the tailgate.<br><br>I bought it from hitch finder for $27.50 plus shipping (part # 20027).<br><br>Thanks for the replies,<br><br>Tim
Hoss, that is it. The hole in the bumper is a large enough circle to accept the slightly larger plug. I had to trim about a 1/32" off of the black plastic cover on the bumper. Then it lined right up and bolted in. Hooked up the 4 prong connector and spliced the brake stuff.
Hoss,<br><br>I have a drop in bed liner and cut my holes for my gooseneck hitch and with this there is enough room in the drivers side rear bed liner to put a standard female plug in. Get the reese Y connector for your normal lights and run wire up the drivers side tail light and through a hole at the top into the bed. Run lines from the connector to the 7 pin standard hitch connector and splice in for hot and brake liness and last run a new ground.
<br><br>Here is what it looks like done.<br>https://www.dieseltruckresource.com/...9&pid=1078<br><br>Hope this helps. Srigs
[quote author=latitud_rt link=board=11;threadid=15797;start=0#148699 date=1055449616]<br>I decided to buy a 7' extension and just run the cable over the tailgate and down to the factory plug. I am going to cover the cable with water pipe foam insulation to make sure it doesn't rub the tailgate.<br><br>Tim<br>[/quote]<br><br>I have been running my 5th wheel wiring over the tailgate since '93 and it has not rubbed through yet. Many, many, many miles. I don't think you will have a problem with rub through.
klx650a2
Dec 3, 2007 03:06 PM
onearizoldman
Jan 15, 2004 11:19 AM
