5th Wheel Hitch Installation Rant
Old May 13, 2010 | 08:31 AM
RollsCoal's Avatar
I am currently installing a pyrometer in my great uncle's 2007 Cummins mega cab 4x4, and I noticed that whoever installed his fifth wheel rails in the bed, tightened the U-bolts so tight that they crushed the ribs in his bed!!! I would be furious if someone did this to my $40k truck. Have any of you guys had this problem? I thought there should be a spacer which would prevent this from happening when tightening the mounting bolts.
Old May 13, 2010 | 09:07 AM
CoastalDav's Avatar
I had rails installed on three trucks, none crushed the bed ribs. All installed at Camping World.
Old May 13, 2010 | 09:16 AM
rebal's Avatar
No, but when mine was installed they pushed the rear bolts from the inside out and the first time I hooked up and hit a big bump the bolts bent past the rear of my springs and locked the suspension in a loaded position. had to use a sawsall to cut the springs free
at first I thought I broke an axle or springs.
Old May 13, 2010 | 09:45 AM
powderman426's Avatar
The easy install kit I bought (Easy is a misnomer) had spacers to keep it from being crushed. They were not easy to get in the rails, so I would guess someone took the short route and didn't use them. Thats why I do My own work. If I don't like the outcome, I know who to blame.
Old May 13, 2010 | 09:56 AM
RollsCoal's Avatar
I agree. I do 99.9% of all my own work. I'm not letting some jackleg mechanic commit a FUBAR on my truck.
Old May 13, 2010 | 10:39 AM
tankeryanker's Avatar
Yep they should have had spacers.
Old May 13, 2010 | 10:48 AM
Also if memory serves me correctly, Those bolts are suppose to be torqued to 100-110 ft lbs. If the spacers are not there I seriously doubt they are tightened properly unless they got crushed to the point that the top & bottom of the channel make complete contact. Not good when trying to pull 10-15k.
Old May 13, 2010 | 10:53 AM
nkennedy's Avatar
Mine came with spacers too, and I used them when I installed the hitch.
Old May 13, 2010 | 02:19 PM
1-2-3's Avatar
Just a plain ole guy
Put my own hitch in. Spacers here.
May 14, 2010 05:06 PM
WJB
Aug 1, 2003 09:49 AM
kamper
Mar 29, 2003 10:13 PM
bobs03
Jan 3, 2003 09:00 PM
moss2904
Oct 29, 2002 08:27 PM
