30 Amp Short Stop
30 Amp Short Stop
Help, my trucks charging fuse (20amp) keeps blowing. My trailer plug harness goes into a "junction box" on the front of the trailer where all the wires are connected and exit as the trailer loom. One wire is connected to a post on what I think is a breaker, and then another wire leaves on the opposite post. Trying to solve the shorting problem, I notice the breaker posts where extremly rusted. When loosening the nut to remove the wire, one of the posts broke off. I was wondering if this was the problem, so I replaced the fuse and touched the two wires together, eliminating the breaker. Pow.......that didn't work. Does anyone know if that breaker has to be there or not. I though possibly I had a bad connection and now I don't have any breaker in line and possibly this could be causing the short. Sorry for being long but we're leaving for a week and now I've got this problem. Thanks in advance.
ga
ga
A short is where a hot lead touches ground. A rusted breaker doesn't necessarily short out, but from what you say, I'd definitely replace it. It's there for protection. From what you say, it sounds like power comes into that panel, then is distributed to the trailer.........?? I would mark each of the wires going out of that panel, make a diagram, so you can get it back together the same way, then disconnect every wire and make sure nothing is touching. Then, with an ohm-meter, start checking resistance of each wire to ground. Should show some amount of ohms. If any don't, trace them out till you find the short. No easy way that I know of.........just time and effort. A little more rough and ready way would be to unhook all the output wires, put in a new fuse and start touching wires back to their terminals till the fuse pops. It'll probably throw a good spark, too. That's your bad guy. Trace it out and fix the short, then go camping. Good Luck ! ! !
Lar.
Lar.
DJ Turbo.
11-05-2011 12:20 AM
Joseph H. Smith
07-25-2007 07:31 AM
slivertruck
25
11-08-2006 08:35 PM
royta
11-06-2006 08:19 AM
