3 car hauling ansd a SB truck
Old Sep 19, 2008 | 12:29 AM
2500CTD's Avatar
Anyone make a 3 car trailer that will work on a SB truck?
Old Sep 19, 2008 | 10:24 AM
haulin-rv's Avatar
First a sb 2500 isn't going to handle the weight. Second a wedge style is not an option is a sb due to clearance issues, so the only option is a flat deck trailer like this.
http://www.kaufmantrailers.com/heavy...auler-p76.html
Old Sep 19, 2008 | 10:31 AM
2500CTD's Avatar
I thought I saw a wedge trailer that held 2 cars and the third was under the deck. Had to unhook the truck to get the car loaded. OK I wanted to see if they made a wedge with the frame setback so as to not hit the cab. I was looking into a bumper pull 2 car trailer but moving 3 would cut down the trips.
Old Sep 19, 2008 | 10:37 AM
haulin-rv's Avatar
Go with the flat deck, 48ft of deck. $6999 new. The belly load is made by wally mo, but its actually a four car.
A wedge on a srw (2500 even worse) is an unstable proposition. The high center of gravity is just not good w/ a srw.
Old Sep 19, 2008 | 11:15 PM
2500CTD's Avatar
I was concerned about being top heavy without the extra track width in the back. Guess its a flat bed. Thanks.
Old Sep 20, 2008 | 09:11 PM
J&L's Avatar
J&L
the 2500 Dodge only has a 6000 RAWR on the short or long bed and thats not enough axle capacity/tire caps for a 3 car hauler if your concerned with being legal. Even a 2 car hauler can overload a 2500 rear axle/tire caps if the first vehicle is heavy. I had the same '01 as yours and its empty rear weight was 2730 lbs which left 3250 for a payload. I stuck with the 2500 truck as I can pick my loads for a short run.
Old Sep 26, 2008 | 03:49 PM
tool's Avatar
Well you could get a Mega Dually and have a SB with added pin weight abbillities.
dodgeguy71
Aug 15, 2006 06:12 AM
Fronty Owner
Mar 30, 2006 06:59 AM
tmoon
15
Feb 1, 2005 09:01 PM
Craig93
Jul 3, 2004 02:27 PM
shortround
Jan 28, 2004 07:28 AM
