2 questions...
Guest
Posts: n/a
2 questions...
TWO questions:<br><br>1. Am I the only one having a problem getting results from the "search" feature? I can pick out a current subject and poster, enter those parameters, and STILL get a "not found" or similar result...<br><br>2. How do you post a picture DIRECTLY in a post, rather than uploading a picture and merely getting a pointer to that picture in the post - the pointer is OK most of the time, but sometimes that actual pic would be more appropriate...<br><br>Thanks...
Re:2 questions...
Gary,
1)
I have not had any issues with the search, but I have not used it since the hosting site was moved.
2) This may not be the easiest way, but this is how I do it.
At the bottom of each reply you make, there is an attachment box. Attach your photo.
Then post.
Once posted, I click on my own attachment in the post, then copy the URL.
I go back and "Modify" my post and use the "Insert Image" button at the top.
When it asks for the image, I paste the URL I copied earlier.
Like I said, it may not but thats how I do it.
(Also, as I understand things, making the photo an attacment first, then inserting it as an image makes it faster for the dial-up members to load the pages)
Hope this helps.
Rich.
1)
Then post.
Hope this helps.
Rich.
Turbocrazy
Feb 25, 2013 04:40 PM
popeye4wheeler
Jan 30, 2011 06:24 PM
Clucker
22
Sep 24, 2009 09:34 PM
GR40RCapri
Oct 30, 2007 09:37 AM
gman07
Apr 15, 2006 08:32 PM
