Yet another injector ?
Old Sep 14, 2004 | 10:52 AM
MLR1's Avatar
Hi all,
I just picked up a set of used injectors and my question is. Do I need to get new sealing washers and O rings before install, or can they just be reinstalled?
Old Sep 14, 2004 | 10:55 AM
BigBlue's Avatar
I'm pretty sure you need new washers, don't know about the o-rings. I'd replace them both. Cheap insurance against leaks.
Old Sep 14, 2004 | 11:11 AM
MLR1's Avatar
Thats what I was thinking but thought I would ask anyway. I have installed a couple of sets of injectors but they were all new. Can anyone tell me where the best place to get washers & O rings?
Old Sep 14, 2004 | 09:23 PM
BIGHEAD's Avatar
MLR1, I have a habit of doing the unorthodox, so here goes. I have replaced & swapped several sets of injectors between vehicles. I have never put new o-rings or washers on them. I haven't experienced any problems either. I do take a wire brush & carb cleaner to the tips & polish them up as much as possible. I also found that the last time I installed my EDM's, it is not necessary to take the fuel lines loose from the VP44 as I had previously done. Just loosen the LINE RACK, & the break the lines loose athe injector tubes. They will move just enough to change everything.
Old Sep 14, 2004 | 11:45 PM
kyle@ftlb's Avatar
Muted User
New coppers and o-rings aren't a must. You wont have a problem if you reuse them.
Old Sep 15, 2004 | 09:45 AM
MLR1's Avatar
Thanks for the replies. The new to me injectors will arrive today. I think I will try just installing them and see how it goes. It feels like x-mas in September!
Max
MikeThomas
Mar 23, 2007 09:29 AM
downlow
Feb 24, 2007 09:38 PM
Jezzhuntin
Aug 25, 2006 02:51 PM
yrusoslow2
Sep 26, 2003 11:08 AM
twhite
13
May 15, 2003 01:03 PM
