Would Edge Comp be beneficial?
Old Sep 5, 2005 | 01:45 PM
B.A.Ram's Avatar
Ok I am debating on selling my EZ and getting a comp, but I have a few questions.
1) Is it a mess to tap into the VP44 or can it be done "ops" style so that it can be removed for warranty purposes?
2) Does it maintain beneficial mpg levels as long as you don't have it on 5x5?
3) Will the stock clutch hold up and will banjos be sufficient for fuel flow?
4) What improvements are there over the EZ?
5) Will I need to upgrade anything besides what I have in my sig.?
6) Am I looking at multiple LP failures?
Old Sep 5, 2005 | 02:52 PM
CTD2001's Avatar
I would go for it, I got a pump cover from blue chip, that way i was able to pierce the wire, when i had warreny work done, i removed the cover and put the stock one back on and the dealer had no idea. Get a fuel pressure gauge to monitor it, you should be fine though if you have a strong lift pump. 5x5 might be a bit to much power for the clutch, but dirving around on 3x5 should be just fine
Old Sep 5, 2005 | 03:12 PM
Tiny's Avatar
I have had mine for almost 2 months now, and still cannot get the smile off of my face!!
For Q1, recite the following - I am my own warrenty station, repeat, repeat
Q2 - All depends on how the right foot reacts to the new found power, mine has gone down, but smoke has increased exponentially
Q3 - Probably not, and hopefully one of those gauges in for fuel pressure, keep an eye on it. I will be adding a pusher pump to aid in maintaining higher pressures
Q4 - More power, more smoke, adjustability on the fly
Q5 - All depends on how hard you run it
Q6 - No more than normal
Enjoy, it definately deforms the facial muscles for a while!!
Old Sep 5, 2005 | 05:31 PM
B.A.Ram's Avatar
anyone know the reliability of these boxes? I know my first Edge EZ crashed within 3 months. I am looking at a used comp but it is out of warranty.
Old Sep 5, 2005 | 08:33 PM
blackdiesel's Avatar
Registered
i bought mine off of ebay used. works like new
Old Sep 5, 2005 | 09:18 PM
B.A.Ram's Avatar
how's your clutch holding up BD?
Old Sep 5, 2005 | 10:45 PM
displacedtexan's Avatar
Don't know about his but HOHN seems to be actively trying to trash his clutch, and is not having a whole lot of luck...
Old Sep 6, 2005 | 07:05 AM
CTD NUT's Avatar
B.R.Ram,
FWIW, my stock clutch is holding up well with RV275's and the Comp on 5x5 - though, I'm not sure why (I would have thought the 275's would have pushed the clutch over the edge) ......after owning a Comp for awhile, I see no reason or benefit to bother with an EZ.
Old Sep 6, 2005 | 10:20 AM
1ST GEN.'s Avatar
You could always keep the Ez and stack it with a TST PM3 or a Bluechip box
Old Sep 6, 2005 | 06:40 PM
B.A.Ram's Avatar
How good is that for the truck?
Old Sep 6, 2005 | 06:43 PM
1ST GEN.'s Avatar
Thats what I am running you get fueling from the TST and timing from the EZ
Old Sep 6, 2005 | 08:20 PM
B.A.Ram's Avatar
How much is that TST? Anyone have an Edge comp for sale?
Old Sep 6, 2005 | 08:24 PM
1ST GEN.'s Avatar
Check Piers they ussually have good prices
Old Sep 6, 2005 | 08:33 PM
B.A.Ram's Avatar
What is Piers?
Old Sep 6, 2005 | 08:45 PM
1ST GEN.'s Avatar
Piersdiesel.com
O.T
27
May 7, 2008 11:54 PM
mx684
13
Jul 24, 2007 07:52 PM
Treangen
May 9, 2007 04:46 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
