Will 3rd gen intake horn fit on a second gen?
Old Oct 13, 2005 | 05:42 AM
pwrtripls1's Avatar
Arrow Will 3rd gen intake horn fit on a second gen?
I am in a hurry and need to know if you can swap them, before this guy sells it to someone else.
Thanks for the help.
Old Oct 13, 2005 | 06:10 AM
CTD NUT's Avatar
Why do you want it? The 3rd gen intake horn is very restrictive.....It should bolt on but I'm not sure if the end of it is aligned properly to accept the orientation of the 1st gen intake pipe.
Old Oct 13, 2005 | 07:11 AM
pwrtripls1's Avatar
I want it because I dont have an intercooler, and I'm installing a 2nd gen IC. The charge pipe I will be piecing together from both 2nd and 3rd gens. I want it to look like it was there stock in the end.
As far as restrictive, nothing a little porting cant fix.
Old Oct 13, 2005 | 07:21 AM
CTD NUT's Avatar
Well, if you look at the bottom of the 3rd gen horn, you will see the way the mounting bolts go through it.....the way the casting accomadates the bolt is silly....it necks down the opening far too much.....porting will not change this. This is why it is common to see the 3rd gen air horn swapped out to an aftermarket unit.....there have been claims of higher boost pre-horn than post horn - especially when the boost is turned up - it is that restrictive......if you can get your hands on a 2nd gen horn you would be better off.
Old Oct 13, 2005 | 09:15 AM
Gotlift01's Avatar
I agree with CTDNUT, I would shoot for a 2nd gen horn. It should be a lot easier to work with, the 3rd gen motors changed quite a bit even since the 2nd gen motors.
Old Oct 14, 2005 | 03:10 AM
pwrtripls1's Avatar
Maybe I should just shell out the $300 for the Bank$ High Ram? I found one on ebay for like $150.
So the 2nd Gen horns are less restrictive than the more powerful 3rd Gens?
Old Oct 14, 2005 | 06:02 AM
CTD NUT's Avatar
Yes.....if you can get a high ram for $150, I would grab it.
Old Oct 14, 2005 | 09:44 AM
Gotlift01's Avatar
[QUOTE=pwrtripls1]Maybe I should just shell out the $300 for the Bank$ High Ram? I found one on ebay for like $150. QUOTE]
Yeah ****** that sucker up, it will be your easiest route and save you a lot of frustration trying to make that 3rd gen one work!! And yes, 2nd gens are a lot less restrictive than the 3rd gens
Captain
Sep 9, 2008 08:30 AM
dieselcarpenter
Mar 26, 2008 05:08 PM
natlchamp2k4
Mar 13, 2007 05:47 AM
bigred496
Jun 1, 2004 09:19 AM
