Why not bypass fuel heater?
Old Sep 22, 2008 | 08:15 AM
Big Smoky's Avatar
I know the fuel heater on the 12v's can be a source of leaks and issues, so why not bypass it using a good filter such as a FASS and just run it straight from the pump to the IP or from the factory LP to the IP? Just something I've been thinking about.
Old Sep 22, 2008 | 10:44 AM
Diesel Doc's Avatar
I havn't had a fuel heater for about 2yrs now. The FASS pump has provision for fuel heat if you need it.
Old Sep 22, 2008 | 08:26 PM
bridleman's Avatar
this is something I was wondering about, I live in Montana and obviously it gets cold and I was wondering if the Air Dog 150 has a way to heat the fuel since I bypassed the the stock one does anyone know if this will be a problem?
Old Sep 22, 2008 | 08:28 PM
need12v's Avatar
Yeah but the FASS fuel heater is only going to work when the coolant is up to temperature, not when everything is 0*.
That being said, warmed fuel from the IP will return to the tank once the engine reaches temperature so its not necessary.
Back when I was running a holley blue with a prefilter, I got ahold of some bio and the temp. dropped. 10% bio will wax at 10* and plug a see-thru prefilter. Wound up heating the prefilter with a propane torch my buddy brought me to get the truck going and then used the diesel 911 stuff from power service. I now carry a quart of that stuff in the toolbox. They say a quart of 2 stroke per tank will stop gelling and add lubricity as well, and I find it to be true, as I never once gelled last year with NO fuel heater.
Old Sep 22, 2008 | 09:25 PM
Big Smoky's Avatar
Living in Texas, I won't be anywhere close to needing a fuel heater! lol
Old Sep 22, 2008 | 09:26 PM
bridleman's Avatar
So will it be possible that i have problems with the Air Dog gelling fuel this winter??
Old Sep 22, 2008 | 09:58 PM
Big Blue24's Avatar
You won't have problems if run Montana's standard winter blend of No1/No2 or straight No1 when it gets down to -20*F. You can also add Power Service additive to the standard #2/#1 blend they sell and get your -20*F non-gelled starts.
Old Sep 23, 2008 | 11:48 AM
kawi600's Avatar
I replaced the heater/strainer along with the filter assembly and went with a racor 490R with the heated bowl and WIF kit. So far Ive been happy with that.
I unplugged the heater and taped up the wiring then re-routed the hose and plugged the heater.
Old Sep 23, 2008 | 06:15 PM
Dartmouth 12V's Avatar
There are two separate issues with bypassing the heater which are the actual heating and the prefilter.
The heater is strategically placed just before the filter because that is the first thing that is affected when you start to gel up. For the vast majority of people, they will never need this heater but it will benefit some in colder climates. What I have done is to unplug the relay for the heater so that I won't have problems with air leaks developing from it getting too hot and I have the option to plug it in if my fuel pressure drops.
The other issue is that on most of the 2nd gen 12vers, the heater also contains the prefilter. This is the only filter before the lift pump and is the one that screens out large particles so I would not completely get rid of it unless you install other filtration in its place. If you don't need the heater part, it is possible to remove it from the unit while retaining the prefilter which is a good option for people who stay away from really cold places.
Old Sep 24, 2008 | 01:08 AM
MikeR's Avatar
You can take the POS heater out.
Just inscrew the bowl, unscrew the heater, and screw the bowl back on, it's the same threads. The bowl contains the prefilter.
Old Sep 24, 2008 | 11:54 AM
Mike Holmen's Avatar
The Guru
I haven't used mine in years. Its not cold enough up here either. The stock filter/heater drops the pressure to much for me, so I don't use it.
ktmrdr85
50
Dec 20, 2016 11:30 PM
freight train
May 28, 2010 02:37 PM
patpat paul
Jan 24, 2009 02:15 PM
sgrooms
21
Apr 8, 2008 11:17 AM
75bronco
Jan 22, 2008 09:31 PM
