Why are factory wheels more resistant to corrosion?
Old Jan 31, 2008 | 02:45 PM
balingwire's Avatar
Why are factory wheels, both chrome steel and aluminum, more resistant to corrosion than aftermarket wheels? Factory wheels are so much easier to maintain. Factory aluminum wheels with "JW" cast into them are so easy to clean. Are there any aftermarket chrome steel wheels, caps, and lugnuts that resist rust/corrosion like factory chrome steel wheels?
Old Jan 31, 2008 | 03:46 PM
Jfaulkner's Avatar
Muted User
The aluminum ones are clear coated. The reason aftermarket ones aren't is because when the clear chips off or gets cracked, they corrode under it and leave white streaks (which the factory ones will do also) Alcoa is the only brand that have "Durabrite" wheels that never need polish, won't corrode and are not clear coated. (I don't believe they're available for pickups though). I know of a few chrome factory wheels that rust but mainly on trucks that never see a car wash.
You can get aftermarket wheels coated but like I said when they go bad they look REALLY bad.
Old Jan 31, 2008 | 10:19 PM
IntakeRacing's Avatar
not true. 02 dodge with alcoa rims was in the shop. looked good.
Old Feb 1, 2008 | 01:35 AM
hink's Avatar
http://www.alcoa.com/alcoawheels/nor...ht/lt_home.asp
Old Feb 1, 2008 | 07:07 AM
Jfaulkner's Avatar
Muted User
I know Alcoa makes pickup wheels but they're not the "Durabrite" version that has a special treatment to resist corrosion.
Old Feb 1, 2008 | 07:12 AM
Ph4tty's Avatar
I did a quick search of their site. Durabrite are available in 19 and 22.5 from what I could fine. Alcoa does make 16" rims also, but I could find no mention of durabrite on those =\
Old Feb 1, 2008 | 10:59 PM
Tate's Avatar
My alcoas are polished on one side or another, but do not have the durabrite finish.
bootsdodgejn
MDDTR #33
Sep 8, 2009 07:28 PM
olympiccop2002
14
Jun 16, 2008 09:11 AM
sgrooms
21
Apr 8, 2008 11:17 AM
CDoskocil9
15
Jan 25, 2007 02:12 AM
AK RAM
Mar 4, 2005 12:20 AM
