why do i have to push gas pedal to make truck start? p pump
Old Nov 25, 2010 | 12:05 PM
banks twinram's Avatar
i want it to start right up like my old 1st gen rotary pump did!. i know these trucks did when they were new. does taking the fuel plate out have anything to do with it?
Old Nov 25, 2010 | 12:33 PM
G1625S's Avatar
'Bout the only think you can do is raise the idle speed. The VE on the 1st gens governor holds WOT untill about 400rpms when the flyweights come up to speed. That's why a 1st gen starts so fast and has a little puff. The p-pump is at idle when not running. I believe it even says in the owners manual to give a little pedal pressure when starting.
Old Nov 25, 2010 | 01:02 PM
The P-pumped motors do like you to depress the pedal when starting.
As the motors get older the idle sometime will get lower in RPMs making it worse.
It is an easy fix to raise the idle and it will make the truck start better without using the pedal.
Do a search on "P-pump idle adjustment"
It is a one wrench affair.
That makes sense [G1625S] as those 1st gens do start so fast!
Old Nov 25, 2010 | 04:52 PM
patdaly's Avatar
Don't know why, but your owners manual says you need to.
Mine will start after several revolutions and no throttle, but I don't like to run the starter more than is needed.
Undertaker
Aug 5, 2010 02:25 PM
sgrooms
21
Apr 8, 2008 11:17 AM
Timmer
Sep 26, 2007 11:54 PM
rcts
Nov 13, 2006 09:44 PM
DL1221
15
Oct 25, 2006 11:11 AM
