Where Can I Get A Heat Sheild For A BHAF
Old Jun 1, 2007 | 03:05 PM
EverydayDiesel's Avatar
I got my BHAF in, man is it HUGE!
Im not that great working with metal so is there a place that sells them? I suppose that I could make it out of aluminum and cut it with a drimel but that would take forever. What are the rest of you cutting yours with? plasma cutter? Is there a place that sells them?
Old Jun 1, 2007 | 03:11 PM
I already have the template. How are yall cutting the aluminum? Anyone tried it with a drimmel?
Old Jun 1, 2007 | 03:23 PM
Mike Stowe's Avatar
A Dremel would work, but I used a jigsaw. It didn't really take that long, maybe 30 minutes to cut, dress the edges, and bend it. And mine is steel. Aluminum will cut much quicker and easier.
Old Jun 1, 2007 | 03:26 PM
mr T's Avatar
u can use a regular grinder...just put the aluminum on a board or somehting...and then just shape out the imperfections with a bench grinder ...
Old Jun 1, 2007 | 04:18 PM
tom25's Avatar
put WD40 on your saw blades when cutting aluminum, It will keep the blade from loading up. just a little trick.
Old Jun 1, 2007 | 04:33 PM
Adam3291's Avatar
I'm debating on getting a different set up than the BHAF, PM me and we can discuss my heatsheild.
Old Jun 1, 2007 | 11:03 PM
I made one out of steel...it wasnt that hard at all
Old Jun 1, 2007 | 11:21 PM
annabelle's Avatar
I'd use a jigsaw as was said earlier. Or plasma cutter.
Old Jun 2, 2007 | 11:24 AM
haloman's Avatar
Where can I find the template for the heatshield and for template to cut the hole in the fender for more air?
Old Jun 2, 2007 | 11:29 AM
Lary Ellis (Top)'s Avatar
Admin Team Leader
We have a free template to download in the tech facts section
Old Jun 2, 2007 | 12:12 PM
haloman's Avatar
Thanks Lary didnt think about that. What about the hole in the cowl/fender?
Old Jun 3, 2007 | 12:38 AM
it already has a vent that pipes cooler air to the side.
just remove the stock box and install the shield.
Old Jun 3, 2007 | 12:45 AM
the heat shield template is here
https://www.dieseltruckresource.com/...n&onlynewfaq=1
fullpull108
Aug 29, 2011 05:29 PM
efrantz
Sep 22, 2007 11:56 PM
Blackbomb77
Aug 27, 2006 09:45 AM
rockwithjason
Nov 13, 2004 06:44 PM
