BHAF heat sheild vs evaporator
Old Aug 26, 2006 | 01:00 PM
Blackbomb77's Avatar
I need some advice from the experts (you gents). A few years back, I put a BHAF on my 2001. Bought it from a TDR member that made them and it came with an aluminum heat sheild. Lo and behold, the heat shield has been vibrating and eating through one of the aluminum evap lines and eventually it's going to ruin it if I don't do something about it.
I need some advice on where I can get a better heat guard/shield for the BHAF?
The help is appreciated.
Old Aug 26, 2006 | 01:11 PM
Joker12valve's Avatar
When i made my heat scheild i trimed it so it would not touch the lines, And if still was i used rubber fuel line to protect it. I haven't had a problem with it.
Old Aug 26, 2006 | 02:13 PM
hotdram's Avatar
I was concerned about that as well. Like Joker12valve, I trimmed mine a little more than what the pattern on this site shows. I also glued rubber (found some that was like a C-channel) around the edges near the evap. lines.
~Rob
Old Aug 26, 2006 | 11:38 PM
dsl kicks gas's Avatar
where's the pattern at??? i made my own out a peice of cardbord and made the sheild out of 304 stainless
Old Aug 27, 2006 | 01:12 AM
i found it
https://www.dieseltruckresource.com/...n&onlynewfaq=1
basicly the same thing i have
Old Aug 27, 2006 | 08:53 AM
Mopar1973man's Avatar
Put some rubber hose over the evap lines to protect them...
Old Aug 27, 2006 | 09:45 AM
dodgeguy71's Avatar
I made my own pattern out of cardboard as well and kept the shield away from the lines and put foam under the bhaf to raise it off the lines as well.
fullpull108
Aug 29, 2011 05:29 PM
efrantz
Sep 22, 2007 11:56 PM
EverydayDiesel
Jun 3, 2007 12:45 AM
rockwithjason
Nov 13, 2004 06:44 PM
