Whats The Difference Between The Edges (EZ, Juice, Attitude)?
I already have gauges and Im curious what the difference is between the different edges. They have the EZ, Juice, And Attitude. Which one does everyone recommend getting?
They have EZ, Comp, or Juice with or without attitude. Price is the big difference... price and about 60 more Horsepower.
Comp and Juice are identical other than the Juice has built in harness to moniter engine parameters such as boost, egt, temps and pressures. Attitude is the monitor that displays this info and allows you in cab adjustability. Comp is in cab adjustable and the best choice for you if you already have gauges. EZ just does fuel and timing within the preset limits of the injection pump. The comp and juice have an optional wire tap that unlocks that extra 60 ponies by manually controlling the solenoid in the injection pump and causing it to open for a longer duration.
do you need the in cab adjustably? I would probably just leave it on 3 and go. I dont think I would be switching it back and forth. i found a guy that will sell me his used EZ module for $300 is the reason I ask
you may not really "need" it but it sure is nice to have. i know with my programmer i sometimes wish i had in-cab adjustability that way when i want to play i can bump it all the way up and when i need to hook up to a load i can turn it down....if you dont play much and are just wanting good power all around the EZ is a good chip, or the comp if you already have gauges as stated earlier just my $.02 haha
hunter
hunter
Get the Comp, because if you get the EZ in 6 months you'll want "More Cow Bell"
And yes the in cab ajustability is great. Want economy or race just push the button.
I started with the EZ and moved to the Comp w/ wire tapped. Love it!!!
You should be able to easily find a used EZ for $200-ish. I had found one for $150. So, don't buy one from that "friend" for $300.
A used Comp should be around $300, maybe that's what you meant....
whats the best price on the edge juice with attitude right now?
I might as well get that one because Ill want it later if I dont.
Plus I dont really like having gauges on the A-pillar
Actually, you change settings a lot more often than you would think.
3 while towing boat only
2 while towing boat with camper on
1 while wifey is driving it
5 for fun
I guess I don't use 4 too often....
5 for fun
I haven't compared the prices for the Edge but these guys have really good prices...take a look.
http://www.thoroughbreddiesel.com/edge/dodge_juice.htm
Actually, after searching it appears the price is the same everywhere. $809 with free shipping.
Chopper_Bob
15
09-16-2009 06:51 AM
jmccart
07-08-2009 04:06 PM
sallyman1
12-09-2007 07:40 PM
razor6
22
01-20-2006 03:43 PM
