what do you think?
what do you think?
I found these injectors on ebay. They sound really cheap. Are these good injectors or should I stay away from them. They are Jammer injector nozzles. Stage 3. Thanks.
http://cgi.ebay.com/ebaymotors/DODGE...mZ380052565452
Just to make sure you are aware, those are only the nozzles. They are not full injectors. Once you get them, you'll need to have them mounted on a set of injector bodies.
Stage 3 nozzles direct from Edge are ~$245. The full Stage 3 injectors are ~$596.
thanks for the info
Just to follow up, the Jammers are a good "budget" injector. But there are better ones to be had based on all the feedback I've ever heard.
If you do decide to get nozzles instead of full injectors, make sure you have someone spend the time when installing the nozzles on the bodes to get them calibrated to all pop-off at the same pressure. This goes a long way into making them a much nicer injector to run.
cyawallac
Nov 1, 2011 11:37 PM
Totallyrad
Nov 29, 2010 02:34 AM
rossco
Aug 23, 2007 06:17 PM
