What To Do With My Trans.?
Old Dec 4, 2006 | 04:51 PM
mkeanglorldo56's Avatar
Lightbulb What To Do With My Trans.?
OK just got my hands on a 2ND gen. diesel. with i believe the 47RE trans. in it? i also just got my hands on my 4 wheeling truck, an 84 Chevy full size blazer. I'm kind of new at all this so bear with me. i have been reading some of the forums to help me out but I'm looking to do some mods as well as tow that blazer where ever to go wheelin. i dont want to go crazy with hp and all, just like chip, exhaust, intake. i also plan to run 36" tires....the problem I'm having right now is i dont know what to do to the trans so it holds up for me. T/C, VB, clutch packs? it does seem to slip a little now i think and it seems like its not so powerful. I'm finding T/C ranging from i think 600 to 1300 $$ but what should i do?? is the real expensive ones for ppl who do like sled pulling and stuff and the cheaper ones like crap?? any suggestions on upgrading my trans anyone??
Old Dec 5, 2006 | 09:14 PM
jriggs_18's Avatar
A VB and TC would be a good upgrade to do what youre asking and more, but if its slipping now save your money and do a rebuild because once it starts to slip its all downhill from there
Old Dec 6, 2006 | 08:43 AM
what kind and where should i get a VB and TC from?
Old Dec 6, 2006 | 08:45 AM
Mcmopar's Avatar
Where are you located?
Old Dec 6, 2006 | 11:33 AM
AlpineRAM's Avatar
A TC and VB will help a good trans but won't be worth the $$ on a tranny that slips already.
If you are mechanically inclined and have a shop you can overhaul the tranny yourself, the factory service manual can be had at www.techauthority.com - best $$ I've ever spent on my truck.
My experience with aftermarket tranny parts (limited as it is) points me to suggest contacting DTT at www.dieseltrans.com.
HTH
AlpineRAM
Old Dec 6, 2006 | 12:22 PM
RowJ's Avatar
And just an after market TC can be a big mistake... needs at least a VB also. Be sure it's the TC slipping and go from there.
What yr truck?
Fill in Signature & location for added help!
RJ
Old Dec 6, 2006 | 12:27 PM
RowJ's Avatar
... i dont want to go crazy with hp and all, just like chip, exhaust, intake. ....
Be careful. Many of us have said the exact same thing... before we got started!
RJ
Old Dec 6, 2006 | 12:39 PM
BigBlue's Avatar
Like everyone else said, if your tranny is already slipping then just save your money and build the whole thing. First thing I'd do is take it to a local shop and have them inspect it and test the pressures and adjust the bands and swap the fluid and give it a once over to see what kind of shape it's really in. If they say it's in good shape then I'd do a torque converter and valvebody and call it good. I'm incredibly happy with my DTT but there are many different choices out there and you should talk to all of the tranny guru's and find out which one suits your needs the best. Also do a search on here for tranny's and you'll find a lot of info that could also help you make your decision.
Old Dec 6, 2006 | 09:46 PM
well i just got the truck its got 60000 on it now. what would it feel like if it were slipping? maybe its not. i work at a shop (training to be a tech.) and i just did a trans. flush on it. only thing i have really experienced with it was (when it sat all day or night and the first drive) at a stop and went to take off and its like it was not it gear, just reved up then it kicked back in gear...happened a like 2 or 3 times in the past 2 months maybe cuz its starting to get cold out or something i don't know....
Old Dec 7, 2006 | 01:18 PM
BigBlue's Avatar
That sounds like it was just fluid draining out of the converter. Perfectly normal. I usually let mine idle in neutral for about 30 secs to a minute before the first drive everyday to make sure that the entire tranny has fluid in it. If it was slipping you'd feel a shudder.
Old Dec 7, 2006 | 02:04 PM
xmr's Avatar
xmr
m---56 I would recheck your tranny fluid level if it is a little low it will do exactly what you have described. Check it on a level place ideling, with it in neutral not park.
Old Dec 8, 2006 | 11:12 PM
yup i did all that fluid is fine. thanks for the tip about neutral XMR...but back to brands of TC and VB....whats good names?
Old Dec 9, 2006 | 09:23 AM
RowJ's Avatar
http://www.dieseltrans.com/
RJ
Old Dec 9, 2006 | 10:12 AM
Willy91's Avatar
www.gbtransmissions.com
Les Eid
Feb 13, 2008 09:22 AM
nfsommer
Nov 9, 2007 09:36 AM
EClancy
Jan 16, 2007 09:27 AM
djgaston
Oct 30, 2005 03:18 PM
live wire
Jul 21, 2003 07:26 AM
