What BB charger with HX35 for twins
Old Oct 4, 2007 | 11:38 PM
piles's Avatar
After all the feedback and some other informative posts, im thinking this might be a pretty efficient reliable way to go for a 450 to 500hp truck that tows occasionly, would the garrett stg3 work well with the HX, what do you turbo gurus think?
Old Oct 4, 2007 | 11:46 PM
Muddin_dude06's Avatar
I would say a Garrett GT4294r or GT4202r with a 1.15 A/R housing... The GT3788r would be much too small.
Old Oct 5, 2007 | 01:12 AM
HOHN's Avatar
ditto^
If you're going to mix ball bearing and journal bearing, put the ball bearing on top where the spoolup will make a bigger difference. It's also cheaper that way, as large BB turbos can hurt that wallet badly.
The GT4294 can theoretically go to 500hp without getting out of the fat part of the map. The 4202 will go to 600 on the map.
Figure a little less than that for the inefficiencies of twins. I'd say 400-450 for the 4294 and up to 500 for the 4202 with good efficiency, put if you push them hard they'll go a lot farther.
A BB garrett stg 1 or 2 on top with a journal bearing 4294 or 4202 on bottom would work very well, imo. That's essentially the combo I'm hoping to build.
Justin
Old Oct 5, 2007 | 05:17 AM
schoust's Avatar
Not to steal the thread but Hohn I'm looking forward and this stuff gets more interesting all the time! Which Garrett would work best IYHO under my 13ss??
Old Oct 5, 2007 | 08:13 AM
RonA's Avatar
A k31 will save you a bit of money and spools very fast.
Old Oct 5, 2007 | 08:33 AM
piles's Avatar
anyone know a good place to purchase Garretts, the k31 is a Garrett isnt it?
Old Oct 5, 2007 | 11:59 AM
Mike Holmen's Avatar
The Guru
I know that PDR sells them, I'm sure there more out there. Search ebay you might a couple different vendors. If your keeping your HX35, go with the k31 or S400. There hot down pipes available and cold air tubes for that set-up. The K31 is wastegated so you can fine tune your twins. Limit your Hx-35 to around 20psi, any more than that will drive up your drive pressure and will be laggy, smokey and have high egt's. You have to balance the exhaust flow thru both turbo to get them to work for you.
Old Oct 5, 2007 | 12:10 PM
RonA's Avatar
K31 is a Borg Warner turbo.
Old Oct 5, 2007 | 02:34 PM
HOHN's Avatar
If I could see a compressor map for a K31, that would all but seal the deal for me to use it as a primary. The combination of good flow, fast spoolup, internal wastegating and low cost is VERY tough to beat. Wastegating on the primary is VERY important imo, and going to an external on the big charger really cranks the cost and complexity up.
I've been told that the K31 and the garrett GT4202 are very similar turbos as far as mass flow and size specs.
If true, that would make the K31 an almost perfect primary for anything 550hp or less.
Anyone know how many housings are available for the K31?
Justin
Old Oct 5, 2007 | 04:34 PM
RonA's Avatar
The k31 only comes with 1 housing. It is a 1.24(I'll have to look at mine) But don't sweat the number. It spools very fast and easily supports mid 500's power with a 62mm s300 on top. I am getting ready to compare my K31 to my 72/87/1.1 s400.
Old Oct 5, 2007 | 05:13 PM
signature600's Avatar
X2 on the K31 housing...but IIRC, the turbine is the same, and I think housings will interchange. Not exactly sure, but pretty sure
Chris
Old Oct 5, 2007 | 07:34 PM
HOHN's Avatar
I'm actually pleased that the K31 housing is sorta large-- I'd be looking for a little larger A/R anyway to keep drive pressure manageable.
jh
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
mullishacrew
Dec 22, 2008 05:40 PM
Big C
13
Jun 22, 2008 01:53 PM
mykal41
Jun 13, 2008 12:04 PM
