Using Current Turbo and getting another to do twin setup
Old Sep 24, 2006 | 02:23 PM
n0ne's Avatar
I currently have a HTB2 62/14 on my truck.. and i was wondering what turbo i could stack with it to make a good twin setup.. this of course would be the smaller of the two turbo's.. anyone have a suggestion on what i should do ?
Old Sep 24, 2006 | 02:38 PM
dzlfarmboy's Avatar
Probably a HT3B with a 26mm exhaust housing, but with that 62 having a 14mm exhaust housing it's gonna be a pretty big set maybe a little laggy. And your gonna need some bigger injectors.
Old Sep 24, 2006 | 04:36 PM
TxDiesel007's Avatar
Rip Rook
has a 2/3 kit, put an S400 under there and wake that puppy up, but again, do expect some lag....
Rick
Old Sep 24, 2006 | 06:42 PM
blackdiesel's Avatar
Registered
ive got a sps 62. I bought it specifically to stack with a s400/b2. Since you already have the secondary turbo, go to PDW and buy the rest of the kit. It comes with everything that you'll need.
Old Sep 25, 2006 | 07:30 AM
kipo's Avatar
would a 62/12 be a better stack with the s400??? The 62/14 I have now is not bad on lag but i want something that spools faster to keep the in-town driving smoke down between shifts. During the winter it's not bad at all but @ 102 degrees and 90% humidity it gets a little cloudy back there. Would a helix cam clear up the smoke?? To BD or not to BD ??? That is the question.
Old Sep 25, 2006 | 08:58 AM
97crewcab's Avatar
There are plenty of places that make kits and plenty of people who will help you with the construction. The a 12cm housing for your 62 should make it spool quicker and it isn't very expensive.
But if you want to sell your current turbo you can get a BD set for less than 3 bills complete.
Old Sep 25, 2006 | 12:01 PM
paulb's Avatar
I have a HTT 62/14 on top of an S400. It works very well for what I use my truck for. Do not expect the 62/14 in a twin setup to spool faster then the 62/14 by itself. The twins will move more air at a lower rpm, but they will spool (the rate of boost increase) slower. I love my twins and would not consider going back to a single. I drive my pickup almost everyday. I often tow my travel trailer to the race track, and then race the pickup.
I would stick with the 62/14 and not use a 62/12. You will have much better EGT control with the 14. IMO if you are going to use a top turbo with much smaller then the 14, then you either need to do some pretty good waste gate mods, or use an external wastegate.
Paul
Old Sep 25, 2006 | 05:27 PM
kipo's Avatar
Thanks for the reply Paul. I think I'll try it first with the ps/s400 setup and see what happens. It's got to be better than the single. How heavy had you towed with this setup?? I see you're running bigger sticks though.
Old Sep 26, 2006 | 11:27 AM
paulb's Avatar
I don't tow heavy. The most I have towed is right around 10,000#. I just turned the box down and flogged it. Even with the box on 3x5 it won't hit more then 1150 EGT's, unless I really lug it down. 3x5 on my truck is about 510hp. I usually tow with the box on 1x3. Cruise control works better there...
Paul
1974d2004x4
13
Oct 17, 2007 07:47 AM
XBS
May 16, 2007 09:45 PM
dodgeboy59td
Feb 20, 2007 08:25 AM
Ripper406
Apr 10, 2005 02:20 AM
GO 4LO
Jan 1, 2003 10:33 AM
